Door Fitting - A-Pillar Skin - Success
Jim_Gruber
Who Hoo!, success. Driver's side door is not fit and attaches, door opens and closes with the correct thunk, gaps are right, sides are straight. After 3-4 days of futzing with this a couple of tips I can pass on.
1) If forward edge of the door is catching on the A- Post Edge it will slowly but surely bend it outward. Not much but each time you try to force it open it bends a little more, making it impossible to get the door fitted as you cannot jusdge that the skin edge has been tweaked.
2) A rubber mallet does not do the job it getting it straight
3) A hammer and block of wood a little more effective.
4) Best method, the <span style="font-weight: bold">good old adjustable box wrench</span>, adjust as small as possible, place over edge of A skin when door is contacting, apply sideways pressure up and down the edge in small increments. Boom door gap is fixed, edge now straight or curved slightly inwards depending on how the fit needs to be.
After a lot of frustrating days all is fixed.Still need to grind welds off on A-Pillar skin as it got a little tweaked with all of my frustrated efforts and I cracked the weld along the top of the skin.
I spent a lot of frustrated time trying to get this fixed, once it was all aligned it was easy but getting everything close enough to do the final tweaking major frustrating. Only one badly bruised first finger after end of door slipped off jack and got finger caught between edge of door and body of car. Dent in A Post Skin that needs to be fixed as well. Have Bondo will fix. Bruise will heal. Just glad it is done.
jlaird
Jim, I hope you made sure you had enough room for primer and paint as well. Don't ask.
Jim_Gruber
Jim_Gruber
Jack, Got that taken care of. Yes, BTDT, now good gaps all around. Got door lowered so not hitting on top front by windshield, that's a whole tricky area all by itself. Now door has good gaps and shuts with a good thunk and does not needed to be slammed hard to close. I'll send pics when I get a chance. Got to sow off the 3-4 day efforts and cogitating that needed to go on to make this right.
jlaird
Excellent. A good job is loved by all.
Jim_Stevens TR2/3/3A Door fitting- graduate level Triumph 25
M TR4/4A Sequence for fitting door glass? Triumph 7
TR4A_IRS TR4/4A TR4/6 Door Fitting Triumph 3
M TR2/3/3A ?????Early TR3 door fitting problem ????? Triumph 22
CraigLandrum TR2/3/3A TR3 door fitting tips? Triumph 16
jjbunn New Door Lock Fitting Triumph 3
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 6
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
E 3000 Healey Door Checks Austin Healey 1
A MGB MGB a glove box door MG 10
chicken BJ7 Door Fit Austin Healey 27
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
F Door Panel Hardware Austin Healey 3
LAW75 Door Latch Adjustment Austin Healey 22
BoyRacer Door Panel Measurements Austin Healey 3
LAW75 BJ8 Door Locks Austin Healey 2
Cappy Occasional Door Malfunction Austin Healey 1
nichola TR6 Door handle and window crank installation Triumph 0
J Door Draught Metal Clips Austin Healey 4
F Interior Door Handle Removal Austin Healey 2
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
M Spitfire 1500 LH Door Triumph Classifieds 0
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Door Seal Austin Healey 5
chicken Inner Door Seal Trim Position Austin Healey 6
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
