bob hughes
Ok guys
Dire straits here, can not get my newly built engine started. We think that there could be a timing issue, but have checked through the dizzy and it's drive down to the can shaft and can not find any problems there. I am sure that I timed the crank/cam relationship properly when I installed the timing chain and sprockets as I painted the marks on the chain to coincide with the marks on the crank shaft and cam shaft sprockets, but stupidly did not take a photo of it. Without raising the engine and removing the damper and timing chain cover, how can I be 100% sure that the relationship is correct. As far as we can tell from observing the tappets, we have number 1 cylinder with both valves shut at TDC whilst number 6 is - exhaust starting to close and inlet is about to open all as per book.
Ideas welcome please.
Bob
Bob
