Convert to adjustable steering
Steve Huneck
Hi,
I have just removed my horn quadrant/control head from my BJ7 and have found some issues that require attention. I thought I would solicit some opinions on the best way to proceed.
Here is what I have;
A two piece stator tube, the bottom piece has a slot, but the top piece seems to have just been pounded into the bottom piece.
I do not have a nut on the steering wheel end just a circlip, but I do have the large plastic clamping nut.
I have the olive at the bottom end which held the stator tube in place.
I only have one wire, for one horn, running down the tube.
I am missing the trafficator lever (I have a switch on the dash for the turn signals), and a quick peek looks like I am missing the pawls and springs.
So, I would like to replace the whole control head, but can I go with the adjustable version? It is quite a bit cheaper than the non-adjustable.
Any thoughts/opinions/experiences are very appreciated.
Thanks,
Steve
Keoke
I am not sure, but that might be possible provided The lower tube has not been buggered and the fixed steering wheel will accomodate the control head.--Fwiw--Keoke- :cowboy:
hama61
Hello Steve,
The non adjustable control head has a stator tube from the horn push to the steering box (that tube is maybe around 6 feet) The horn push is roughly twice a big as the adjustable one.
These non adj control heads are very difficult to get and much more expensive than the adjustable( can easily be bought aftermarket)
fwiw
Harry
S
Steve Huneck
Hi,
I think I may have a 'modified' adjustable. I have attached a couple of pictures.
Steve
Keoke
Steve Huneck said:
Hi,
Steve
OPPS!!---Keoke- :laugh:
Duane_Rhynard
Steve,
The joint should look like the picture below. Please note in this picture mine is cracked on the end of the slot on the long tube.
Duane
58 BN6
Keoke
Well Steve, I think your initial concept of trickery may be correct. :laugh:
What this looks like to me is the original nonadjustable assembly may have also had a defective stator tube.
Replacing a fixed stator tube to the horn assembly is a bit of a chore
So the[ :jester: ] cut the original stator tube off below the Horn assembly and then forced it on to an adjustable stator tube where the slot in the adjustable tube allowed the mating..---Fwiw--Keoke
Keoke
Hi Duane
The cracked tube can be repaired using a tig weld. However,depending on the shop. the cost may be about the same or more than replacing the tube.--Fwiw-Keoke
Keoke
Well Steve, you might want to give E-Bay a look see. I see them there occasionally.---Keoke
Jerry
I did the conversion to the adjustable for my non-adjustable BN4. It is possible to make this work. The one item which is a little unsightly is the adjustable will stick out of the steering wheel a little too much. Too much gap between the trafficar and the steering wheel. The use of a dremel on the inside of the steering wheel will get these to mate better.
Jerry
BN4
BJ8
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
R 948 convert to 1275 info Spridgets 13
Tiger2Dan For Sale Convert your 4 cyl to a V6 Other British Classifieds 0
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
TRMark TR4/4A Convert from H6 and log to HS6 and 4A intake Triumph 6
jfarris TR2/3/3A 56 TR3 - Convert to Neg Ground or Leave As Is Triumph 18
Boggsy64 MGB Convert away from Z/S a real boost? MG 17
BoyRacer How to convert BN1 to later transmission Austin Healey 4
PATR8 Convert. Top help Triumph 6
RAC68 Wedge TR7 - Anyone Convert from Carbs to EFI Triumph 6
58Custom Is it easy to convert a '69 US dash to a pre-67? Spridgets 21
Go_Dogs_Go Convert Pertronix Pos Ground to Neg Ground? Spridgets 10
N Convert BJ8 exhaust to single silencer Austin Healey 6
Jer convert from 74 rubber overiders to 73 style ? Spridgets 17
Aggudabbu convert cooper engien for spridget? Spridgets 23
M how to convert bn1 gearbox to 4 speed Austin Healey 17
T Check list to convert to front disc brakes Spridgets 9
livinginthepast Any SEA area folks need a convert. top frame-free? Spridgets 24
T TR2/3/3A Convert TR3 to negative earth or leave it be? Triumph 14
Magyar How to convert from positive to negative ground? Spridgets 10
mine Positive convert to negative ground? Triumph 15
R convert to electronic tach Triumph 3
AUSMHLY Instructions to convert to neg ground Austin Healey 5
R Hillman Super Minx Convert for sale Other British Cars 1
G Oil Filter - Paper, Felt or Convert? Austin Healey 15
G TR6 Cost to convert a TR-6 to V8? Triumph 39
Webb Sledge TR6 TR6 Tonneau + Convert Top? Triumph 2
J XJ6 SII Fuel Injection- Convert to carbs or rebuild? Jaguar 6
aeronca65t Convert.Top Cleaner? Restoration & Tools 10
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
kodpkd Adjustable Tie Rods Austin Healey 20
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
T Kilmartin Adjustable Front Shock Mount Plates - Installation Instructions Austin Healey 0
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
J TR2/3/3A TR3A Adjustable Steering Triumph 5
J Wanted Adjustable steering wheel circlip Triumph Classifieds 4
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
steveg SOLD!! Moto-Lita 14" wheel for sale with adjustable hub & collet Austin Healey Classifieds 0
J TR2/3/3A Adjustable vs non Adjustable wheel Triumph 0
Walter74 Adjustable steering wheel removal Austin Healey 4
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
John_Koop TR2/3/3A Adjustable steering wheels Triumph 3
AUSMHLY Adjustable steering wheel removal Austin Healey 5
C Non-Adjustable steering column questions Austin Healey 14
G TR2/3/3A Fitting the Control Head - Telescoping [Adjustable] Wheel Triumph 20
B Wanted Need '58 TR3 adjustable steering set up Triumph Classifieds 4
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
