TR6 TR6 Tonneau + Convert Top?
Yellowdog
In a word, yes.
The factory original tops on our '74 & '75 had buttons on the outside that matched the tonneau so it could be snapped in place over the lowered soft top. These were unique to each car as we could not switch the tonneaus between vehicles. At least we knew which one went where.
I will never be able to explain this correctly . . . . . The top was attached to a stretcher bar (my term) that was attached to the rear deck. A male snap was fixed to the exterior of the soft top for the tonneau. The rear deck of the car also had male studs affixed so the tonneau could be attached without the soft top in place.
So, the soft top could be installed, and then lowered with the spreader bar left fixed and the tonneau installed over the soft top. OR, the soft top could be completely removed and the tonneau installed using the rear deck snaps which were located in the same place as the studs on the exterior of the soft top.
Now that I have cloudied the waters, I will add that I do not have a clue what the new aftermarket tops and tonneau's are like! I would think that you might have to get the top & toneau from the same company at the same time to make everything align. Then again, you could simply install new snaps in the soft top for the tonneau to attach to.
Like I said, in a word, yes.
AltaKnight
I've just installed a new tonneau cover on my 73 TR6, it fits fine over the folded down convertible top as long as it's folded properly. /ubbthreads/images/graemlins/angel.gif
The tonneau covers don't have the snaps attached when you buy them so you can just fit it to match.
My convertible top is not an original it's aftermarket but it works just the same.
R For Sale TR6 TONNEAU COVER ( FACTORY ORIGINAL ) Triumph Classifieds 4
I For Sale TR6 tonneau cover Triumph Classifieds 5
T For Sale Triumph tr6 early tonneau cover - $250.00 Triumph Classifieds 0
mrv8q TR6 TR6 Tonneau Q Triumph 3
mrv8q TR6 TR6 Tonneau Q Triumph 2
I TR6 TR6 tonneau snaps Triumph 7
kodanja TR6 Tonneau for a TR6 w/rollbar? Triumph 10
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
