Cleaning convertible top
auggie
Hi to all,
When I purchased my 60A I received a convertible top and tonneau cover which are materially sound but quite dirty. I have tried the normal cleaners, but short of power washing them I have not been able to get them presentable. What have you fellows found that works well?
Also, is there a product on the market that can remove the yellowing on the rear window?
Thanks.
Auggie
Darrell_Walker
Are the tops dirty, stained, or just weathered? What color?
I've used the liquid shoe polish on old tops (black) to make them look nice.
Novus makes a plastic polish. I've not used it on the rear windows, but have used it on other plastic, and it works quite well.
A
auggie
Sorry, it is a white top, no stains or weathering, just dirty.
Darrell_Walker
Ok. Assuming you've already tried various cleaners and a stiff brush, the next step might be something like OxiClean.
They do also make the liquid shoe polish in white, though I'm not sure that would work as well as on a black top.
ekamm
I used a product called white lightning available at Lowes and likely other places worked well with liberal scrubbing. Make sure to get complete coverage and wash off thoroughly. Make sure that the top is completely dry before storing it or it'll mold in a hurry. For the window I found that a plain tooth paste (white old school colgate) worked quite well. Rub it on the dry window really well and clean of with a wet rag, it may take a couple of times.
glemon
I had a white top on my Healey that cleaned off pretty well with 409 cleaner and lots of scubbing. I would think one of those oxy-clean type carpet cleaners would work well too.
As far as the window, I have used Meguires plastic polish and plastic cleaner (actually somewhat misnamed, as the cleaner has the more agressive abrasive formula, it is the one that will take the yellowing and minor scratches off.) can be used, I have had good luck with it, maybe doesn't restore to as new, but certainly to a usable clarity. Lots of elbow grease required.
Geo Hahn
There was a thread awhile back on cleaning a white tonneau/top. I'm thinking it was lacquer thinner that proved to be the right stuff but don't take my word for it, better to find the thread.
I have cleaned up a bad window with a chrome polish called Simichrome (before plastic polishes were so commonly available) though I have also used some of the commonly available plastic polishes on scratches with amazing results.
PeterK
My favorite all purpose plastic/rubber/vinyl cleaner is Westley's Bleche-White tire cleaner. I use it with a soft brush to get into the texture in the material and get it super clean. Rinse thoroughly. For finish and UV protectant, I use Lexol Vinylex both inside and outside of the car.
af3683 Cleaning Convertible Top Plastic Windows Triumph 4
simpzimmer Convertible top cleaning/care Restoration & Tools 17
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
S TR2/3/3A Parts cleaning. Triumph 4
P TR2/3/3A Block treatment post cleaning Triumph 17
B Electrochemical cleaning of stainless steel welds Restoration & Tools 7
B Car care/cleaning? Lotus 5
Basil Cleaning fuel injectors Restoration & Tools 4
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
L TR2/3/3A Stupid Engine cleaning question Triumph 9
F Undercarriage Cleaning Austin Healey 13
S For Sale Big Barn Cleaning Triumph Classifieds 0
T TR2/3/3A Instructions for cleaning & re-lubricating speedometer? Triumph 5
TRMark TR4/4A Cleaning Striker and Restraint Assemblies Triumph 2
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
NutmegCT Fuel tank cleaning/restoration Restoration & Tools 47
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
SASSAMON TR2/3/3A Help Wanted In Cleaning Corrosion Off SU Carbs Triumph 20
K TR2/3/3A Cleaning the gas tank...what have I done now? Triumph 19
B TR2/3/3A Control column turn signal cleaning Triumph 8
K TR2/3/3A Cleaning a gas tank with muriatic acid.... Triumph 7
PKPoole TR2/3/3A Spring Cleaning Done Triumph 2
E TR4/4A Cleaning of alloy parts Triumph 4
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
S TR2/3/3A cleaning wire wheels Triumph 6
R TR4/4A Question about cleaning instrument faces Triumph 8
G What's Your Best Car Cleaning Tip? Restoration & Tools 0
K TR2/3/3A Speedometer cleaning ? Triumph 3
Gliderman8 General Tech Cleaning sludge/varnish from a gas tank Triumph 6
cologero_100 Cleaning the satin chrome grille on a 100/4 Austin Healey 2
M Cleaning up under the hood - just how much needs to be painted? Spridgets 2
drooartz Cleaning out the parts: gauges, lights, console Spridgets 4
drooartz Cleaning up wiring Spridgets 17
H TR4/4A 4A grille cleaning Triumph 10
simon1966 Parts cleaning? Austin Healey 6
D Finally done cleaning!!! Spridgets 2
Jim_Gruber Spring Cleaning Special - Lower Valance for Spridget off of a '68 Sprite Spridgets 10
M_and_P Spring Cleaning Spridgets 0
JPSmit Cleaning Tip Restoration & Tools 0
T Cleaning a White Interior Triumph 0
drambuie Strip cleaning frames engines and bodys Austin Healey 5
W What size taps and dies for thread cleaning ? Austin Healey 7
Tr3aguy Chemical dipping vs media cleaning? Triumph 4
K Cleaning up exterior surface of SU's? Triumph 8
M Cleaning regulator and cutout contacts Triumph 4
R Lens Cleaning/Polishing Triumph 5
dklawson Gauge Face Coating after Cleaning? Spridgets 1
dklawson Gauge Face Coating after Cleaning? Triumph 2
L Advice for cleaning/painting 1980 rubber bumpers MG 8
S cleaning old plastic Triumph 6
