Carb Needles
fogdot
In looking at my carb needle shafts, they are stamped "369"
I have the tuning book which lists about a hundred different needles, but they are all designated by numbers. Where can I find out how they compare to the "standard" needles?
TR3driver
Great Pumpkin - R.I.P
According to this chart, those are aftermarket equivalents to the SM needles that were standard for TR3-4.
B triple carb needles? Austin Healey 2
R Early ZS Carb Needles Triumph 11
JPSmit New thread - 93 miles tank [Carb needles] Spridgets 0
poolboy Fat Needles... a carb adjustment problem Triumph 4
B MGA Carb needles in MGA 1800's MG 2
A Air cleaners / carb needles MG 5
F Carb needles Triumph 3
Woodie carb needles Spridgets 6
Eleven SU Carb Needles Triumph 0
R6MGS T-Series MGTC Carb Needles MG 7
M Carb needles, roller rockers. MG 2
Got_All_4 STROMBERG NEEDLES FOR 3 CARB SET UP Triumph 2
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
