Carb balance-pipe - REALLY necessary?
SportsSixter
Hi, I have 3 Strom CD150's on my GT6 (1998cc) which sit on 3 seperate home-made manifolds fabricated by the previous owner. He has drilled holes in the top of each and brazed a balance pipe between them (copper elbows, short SS pipe sections and rubber couplers to account for any severe vibration - a neat job). Yesterday while being a little 'vigorous' with a spanner I managed to knock one of the pipe sections off. As I didn't have tools or time to re-affix the part, I removed it from all three manifold sections, and blanked off the holes.
Now the engine starts better than it did, but backfires quite regularly. In fact it sounds like it pops fuel BACK through the carbs and out of the filters.
So.. my questions are, what does the balance pipe do? DO I REALLY need it? Have I done, or will I do damage to the engine by driving it like it is?
Cheers for any info, thoughts, ideas... Ben
CraigFL
The more cylinders you have pulling on the manifold, the more even the vacuum. With a street engine at low idle, the vacuum would be very irregular with only two cylinders per carb. I suspect the balancing tubes would make the carbs function much better. You could probably see this if you put a vacuum gage on the manifold with and without the balance tubes.
SportsSixter
SportsSixter
Hi Craig,
Thanks for the response, so when you say "function much better" can you say in which way that would be? Economy, throuput, power, responsiveness.
I'm deffinitely noticing a difference in 'pull' while accelerating. I used to have a problem with very low power when pulling away but it was ok past about 2k revs. I put this down to the differnt cam in there. But since doing away with the balance pipe, it has WAY more pull at low power. In fact it'll start to pull itself along on the flat if I up-clutch slowly in first gear with zero accelerator - Before if I'd done that the engine would just die.
Cheers,
Ben
AltaKnight
I would think you should check the ignition timing, backfiring through the carbs might mean you're too advanced which could damage the intake valves or the carbs/air filters if bad enough or prolonged.
Try backing it off a few degrees, see if that helps.
SportsSixter
SportsSixter
Oh ok thanks, I'll try that and see if it makes much difference.
I know Craig has touched on it, but anyone else got any thoughts on whether I actually need a balance pipe?
I know Triumph included one in all their manifolds on 2 carb systems, but does anyone really know WHY that was?
I've been talking to Mini and Porsche mechanics and they think the balance pipe is useless.. Triumph MUST have had a reason though...
cheers
Banjo
I wonder if one of the Balance pipes had a vacuume leak, that could have caused the symptoms you described. and eliminating them eliminated the leak.
martx-5
[ QUOTE ]
cheers
[/ QUOTE ]
Although we often may think otherwise, all these things that are on cars were put there by some highly paid engineer that the bean counters approved. That balance tube is there for a reason. I tried to find out what exactly it is there for, and as the name suggests, it is there for "balance". This site on MG's gives some info on the reason it's there and the effects of it not being there. The discussion about the balance tube starts at about the third paragraph down./ubbthreads/images/graemlins/driving.gif
SportsSixter
SportsSixter
Aha.. yes so its possible that since owning the car (3 months ish) I've always had a leak there, and now I've covered it up the power is more even throughout acceleration.
And this pulsing effect is exactly what it feels like.. even sounds like that. I was calling it 'punch'. I was telling the people the engine sounded more 'punchy'. Pulsing is better /ubbthreads/images/graemlins/smile.gif
Thanks guys, thats given me more info to play with.
I think I'm going to re-make the balance pipe. I shall probably make it from 1/2" fuel unions if I can find any that big, if not then some 1/2" (or close) air-line fittings. I plan to 'fine' tap the 3 manifolds (using the existing holes opened out more) and connect the unions/couplings with some 'fuel' proof hose. Any thoughts on this setup?
SportsSixter
SportsSixter
Cheers! I will... i have asked about this on another forum and its looking like I might try running without the pipes for a while. A guy here in the UK thats a bit of a 'carb guru' seems to think the balance pipe is basically an excuse for lazy tuning.
Southwarks TR2/3/3A Carb balance woes Triumph 6
H useless carb balance tool Austin Healey 25
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
wkilleffer Carb balance/adjustment frustration [long] MG 22
C LCB header with 1500 single carb inlet manifold Spridgets 1
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
E MGB SU carb air cleaners MG 10
Healey Nut Tri-Carb Project Austin Healey 213
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
tahoe healey Dumb carb question Austin Healey 23
jfarris TR2/3/3A Happy with my Paltech Carb rebuild Triumph 8
2 TR2/3/3A SU carb. Acts like an expansion valve ! Triumph 10
dbenichou289 TR2/3/3A SU carb linkages Triumph 2
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
O HD8 carb on Healey 3000 Austin Healey 62
