Bugeye engine removal with floor jack
markberry
Hi All,
it's awhile since we've talked about it (can't remember the last time, and I couldn't find the subject with a forum search), but does anybody know the procedure for removing a Bugeye engine with a floor jack? I remember Frank Clarici (rest in peace Bro)was adamant about not needing to pull the Bonnet to pull the engine, and had posted the procedure here or at Spritespot at one time. I remember the starter and oil filter needed to be removed, but can't remember the full procedure.
regards
Mark
TulsaFred
Good question, was thinking about this last week. It's here somewhere but I don't have it.
smaceng
I have pulled the engine/trans on my old BE without removing the bonnet, but I used a engine hoist and leveler. Take off the distributor and oil filter. Disconnect the intake manifold from the engine and lay it over on the inside wing (no need to remove cables). Remove the exhaust manifold. Remove the radiator. Short couple the cherry picker/leveler and the engine, remove engine mounts.....the whole lump comes out through the radiator supports!
Maybe you could lift up the engine with the floor jack from the oil pan to clear the steering rack. May require two young strong boys to lift the engine out!!
Cheers
Scott in CA
Scott, was the car on jackstands when you did that?
Bayless
I remove the engine all the time using a floor jack. Oh wait, that's on the VW. Sorry.:sorry:
M
markberry
Cheers
Scott in CA
I guess it would be more stable with a cherry picker. jeez I was hoping to get away with not disturbing the exhaust/intake, but I like your idea of laying the whole thing on the inner fender.
thanks
Mark
smaceng
Yes, the front was up on jack stands to make it easier to get the angle necessary to clear the rack.
Scott in CA
nomad
I can't quite envision using just a floor jack. You could get the engine disconnected from the trans and move it forward onto the cross member but then you are down to needing a mighty strong back! [Not mine!]
HealeyRick
Hi All,
regards
Mark
Found it!
I just raise the bonnet on it's stays, disconnect everything and use a floor jack to roll the engine out the front.
Remove the dizzy, oil filter, and carbs from the engine so it clears the radiator supports.
Using a jack, roll it forward, jack it up, slide it onto the steering rack (an old towel will keep any scratches away) Once it's balanced on the rack, roll the jack out front and slide the engine back on the jack. It's out.
A helper to hold the engine balanced on the rack helps but I have done it alone many times.
Frank Clarici
Toms River, NJ
The BETTER not BIGGER Healeys
PS It will be 5 yrs on April 11 since we lost Frank.
M
markberry
Found it!
Frank Clarici
Toms River, NJ
That's the post I was thinking about! Thanks Rick! I'm going to give it a try this week; My first tranny rebuild is stuck in reverse:sorrow:.
Hard to believe it's been five years. Frank was a great Dude.
nomad
Thanks, Rick. The engine will be coming out of my BE shortly so I think I'll give that a try. Frank was an inspiration....
TulsaFred
Is this with the transmission still attached?
M
markberry
that's what I'm assuming. it would be a game changer for me if Frank was talking all this time about separating the tranny first before using this procedure.
drooartz Bugeye engine removal is easy! Spridgets 8
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
A Bugeye engine swap, 948 to 1275 Austin Healey 11
P Pinto Engine In Bugeye Spridgets 21
T Newbie Bugeye Sprite owner engine advise needed Spridgets 5
L Engine Mount Thickness for Bugeye, etc. Spridgets 1
I oil/oil additives for stock Bugeye engine? Spridgets 10
I What is a normal engine temp for Bugeye? Spridgets 6
I bugeye 948 rebuilt engine - no oil pressure, Spridgets 7
I Bugeye Engine Installation Questions. Spridgets 10
I Bugeye engine bay picture? Spridgets 6
I Bugeye 1275 engine conversion questions Spridgets 3
J Normal Engine Temp for bugeye Spridgets 1
C Miata engine in a Bugeye? Spridgets 12
B Bugeye Engine tray? Spridgets 10
G Bugeye Spridget with Volkswagen Engine in Georgia Spridgets 2
B frogeye/bugeye turbodiesel engine conversion Spridgets 6
E Bugeye Engine Austin Healey 10
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
