Brosky Off-Road Services
mrv8q
Frank, Paul did say he had a surprise for us, who knew?
Gliderman8
When I saw Paul's modifications, I thought I'd give it a try.
It's not yellow, but it does get the back yard plowed :thumbsup:
<span style="font-style: italic">edit: I sure hope Paul does not get any ideas when he sees those flashy YELLOW wheels</span> :jester:
Brosky
Frank, where do you come up with this stuff???? LMFAO!!!!
I actually kind of like that unit. It reminds me of the mid-70's when doing that sort of thing with Jeep chassis was cool. The guys started putting van bodies on 4WD Chevy & GMC truck chassis and eventually the factory started making them that way.
If only this guy have been 35 years sooner......Sigh.....
angelfj1
angelfj1
Actually, now that I'm retired, I spend far too much time surfing the net.
But,I'm really tickled that you liked it! :yesnod:
Mickey Richaud Hey, Paul [Brosky] - Triumph 2
B Brosky's right!! Triumph 20
drooartz Brosky, nice bit in the papers! Triumph 12
B for brosky Triumph 3
T Post-War Other Brosky, can you rebuild the TRF Italian fuel pump? Triumph 17
T Dang You Brosky....I'm Red All Over! Triumph 6
BobbyD Bet We Won't See Brosky Do This Triumph 19
LastDeadLast Brosky - Front sealing block info? Triumph 15
jerrybny Brosky Sighting?? Triumph 1
T Brosky Triumph 5
T Mr. Brosky's Springs Triumph 4
G Brosky, any feedback on the Spal fan??? Triumph 1
G Brosky, ya got a picture of dizzy drive gear set.. Triumph 10
2wrench Exhaust manifold studs, Brosky Triumph 4
G Hey Brosky! Triumph 1
T calling brosky Triumph 1
N Brosky requested Progress Report Triumph 2
K Brosky question Triumph 5
LastDeadLast Woah, Woah! Brosky, I need a needle! Triumph 10
G The woes of high performance...listening Brosky??? Triumph 12
DrEntropy YO! Brosky!!! [RE: Throttle linkage couplings] Triumph 15
Basil Brosky! Triumph 3
K TR2/3/3A Old school battery shut off switch....... Triumph 3
petnatcar Knock-Off Wrench - The New and Improved Version Austin Healey 12
B TR4/4A Headlights Blink Off Triumph 15
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
Editor_Reid Knock-Off Hammer Austin Healey 8
kodpkd Signing Off Austin Healey 8
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
T Knock-Off Spinners Austin Healey 43
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
G Engine Will Not Turn Off Austin Healey 10
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
Tr3aguy TR2/3/3A Gasket part way off Triumph 10
T TR4/4A Fenders off the car for paint? Triumph 8
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
R Turn Signal Knob goes off center Austin Healey 9
J BJ8 flywheel take some pounds off Austin Healey 17
A Setting Camber Really Off Austin Healey 13
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
JPSmit So I guess I don't need to lay off the churros after all Spridgets 4
S TR2/3/3A Frame off vs. body on restoration Triumph 21
Basil Easy[er] way to get frozen brake rotors off Restoration & Tools 13
B TR4/4A Can't get rear extension off. Help! Triumph 24
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
JPSmit Off to bed for the winter Spridgets 10
TomMull Knock Off Tool Restoration & Tools 6
