Brake pads
Stewart
It's looking like I'm going to be doing front brakes on the 75 as 120 miles in the mountians this afternoon kinda made it clear they need to be done. Slightly warped rotor I think as the steering wheel vibrates under heavy braking but is fine under normal braking.
I'm going with a new set of the stock brembo rotors but whats the skinny on brake pads. I was hoping to hold out for the moss ceramic but they dont have a clue when they are going to be available. Are the ebc green stuff pads any good and how is the braking compared to the stock pad? Better or worse? Also how is the dust? I did change the pads a few years ago with the stock pads moss offered and the dust has been horrible and I'd like to go more than 50 miles without needing to clean the wheels.
PAUL161
Question; I know that TRW usually sells top shelf parts, at least they did in the past, but where are their MG master cylinders made that make them any better than the Chinese junk? Are they made here? PJ
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Ripper01 For Sale Brake Calipers w/ pads- 2 Triumph Classifieds 0
JPSmit Brake Pads - question Restoration & Tools 10
Bob_Spidell Brake Pads for BJ8 Austin Healey 24
RAC68 Singing Brake Pads Austin Healey 34
eschneider Any late-model Mercedes owners willing to review new brake pads/ rotors? Other Cars 4
Lynn Kirkpatrick MGB Disc brake pads MG 4
tahoe healey disc brake anti squel pads Austin Healey 5
Gliderman8 Brake Pads Triumph 8
drooartz New brake pads, wheel is dragging? MG 4
K TR2/3/3A TR3A New Brake pads binding to New drum? Triumph 4
bugedd Front brake pads that dont squeak Spridgets 7
Rob Glasgow EBC Green Stuff Brake Pads Austin Healey 3
C TR2/3/3A TR3 Brake pads interchangeable? Triumph 1
F How to replace brake disks and pads to 3000 mk3 Austin Healey 10
TimK Uneven wear on Healey front disk brake pads Austin Healey 2
abarth69 Brake pads? Austin Healey 5
M Mintex Brake Pads Triumph 5
jdubois Anybody use Porterfield R4-S brake pads/shoes? Triumph 9
H TR4/4A TR4A Brake Pads Triumph 11
S Front Brake pads for 1966 Morgan + 4 Other British Cars 4
D Green Stuff Brake Pads Triumph 12
71tr toyota 4-pot brake pads Triumph 9
T Lucas girling brake pads Triumph 2
Bret Front Brake pads MG 8
D Brake Pads Spridgets 5
G EBC Green Stuff brake pads Triumph 7
W Weathered the front brake pads. *DELETED* Triumph 2
J Replacing Brake pads Spridgets 4
G Front Shock Replacement and Early BJ-7 Brake Pads Austin Healey 5
A brake pads MG 0
S Brake Pads Triumph 5
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
