habaneronut
Well, I've read my manual and looked through the archives, still can't find an answer so I come again to the experts.
I've just found out I've got TR4A brakes on my 3A while trying to install those brake silencer shim to quiet a persistent squeal. I've got the "C" caliper described by Moss as evidenced by the retaining pins with cotter pin fasteners. Hard to tell from the pictures in the Moss catalog, but I think the pads may actually be for the "B" type caliper rather than the "C". They were EXTREMELY hard to remove, had to use vise grips, and even then the inner pad took about five minutes of wiggling to break free.
Once the pads were out, the pistons moved forward enough that there is no way I am going to get the pads back in without some kind of adjustment, even without the new shims. The manual says to push the pistons back to their full extent of travel, but they just don't move. Would opening the bleed nipple a little help, or is it just that some #$@$$6% PO put on the wrong set of pads?
Fred
Fred
