Brake Pads
steve99
Anyone have any opinions about organic or semi-metallic brake pads for a stock brake system on a 79 TR7? (And no they have not killed any body yet either).
MDCanaday
Steve, since the 7 is a little weak on brakes I would go with semi-metalic pads and two brand new rotors. They are so cheap that turning them is a bad option that leaves them thin and prone to warpage.......(in my experience at least)
MD(mad dog)
I would definitely agree on that. Semi-metallic will give you a much better stop on a stock system. I used to change shoes often on my 7 and found that the semi-metallic was much better.
t-rocks69
try the EBC kevlar pads i have them on my 8 very little fade and great stoping power also the metal brake lines..
philman
I also use kevlar pads on my TR7, and a set of cross drilled rotors. seemed to help. haven't upgraded to steel flexible hoses yet (soon).
ObiRichKanobi
I put semi-metallic pads on my -7 this past year, and they do seem to be better than the stock ones. Just be sure to get the shims and the silicone "brake grease" as I had one heck of a squealing problem at first.
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Ripper01 For Sale Brake Calipers w/ pads- 2 Triumph Classifieds 0
JPSmit Brake Pads - question Restoration & Tools 10
Bob_Spidell Brake Pads for BJ8 Austin Healey 24
RAC68 Singing Brake Pads Austin Healey 34
eschneider Any late-model Mercedes owners willing to review new brake pads/ rotors? Other Cars 4
Lynn Kirkpatrick MGB Disc brake pads MG 4
tahoe healey disc brake anti squel pads Austin Healey 5
Gliderman8 Brake Pads Triumph 8
drooartz New brake pads, wheel is dragging? MG 4
K TR2/3/3A TR3A New Brake pads binding to New drum? Triumph 4
bugedd Front brake pads that dont squeak Spridgets 7
Rob Glasgow EBC Green Stuff Brake Pads Austin Healey 3
C TR2/3/3A TR3 Brake pads interchangeable? Triumph 1
F How to replace brake disks and pads to 3000 mk3 Austin Healey 10
TimK Uneven wear on Healey front disk brake pads Austin Healey 2
Stewart Brake pads MG 2
abarth69 Brake pads? Austin Healey 5
M Mintex Brake Pads Triumph 5
jdubois Anybody use Porterfield R4-S brake pads/shoes? Triumph 9
H TR4/4A TR4A Brake Pads Triumph 11
S Front Brake pads for 1966 Morgan + 4 Other British Cars 4
D Green Stuff Brake Pads Triumph 12
71tr toyota 4-pot brake pads Triumph 9
T Lucas girling brake pads Triumph 2
Bret Front Brake pads MG 8
D Brake Pads Spridgets 5
G EBC Green Stuff brake pads Triumph 7
W Weathered the front brake pads. *DELETED* Triumph 2
J Replacing Brake pads Spridgets 4
G Front Shock Replacement and Early BJ-7 Brake Pads Austin Healey 5
A brake pads MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
