BJ8 Windshield re-chrome
Cutlass
Just dragged the windshield from the attic today, and, sure enough, the chrome needs help. Apparently it is chrome plated metal, not aluminum, but not steel either. So what is the metal? Brass like the vent wing frame? Plated stainless? I know the plater will find out, but I want to know in advance, before I start disassembly.
C
Cutlass
Ok, for those who are interested, the main horizontal and vertical pieces are extruded brass. The pillar assemblies are just that, appaarently assemblies of machined brass (the chrome plated part), with stainless steel and mild steel parts riveted thereto. The channels are pretty straightforward for re-chroming, but for a proper job I believe that the pillar assembly must be disassembled. The trick there is to find the proper rivets for re-assembly.
One more thing. On the vertical channels, there are four slotted holes for attaching the corner braces. Being brass, some of mine are wallowed out. Has anyone had any luck repairing such wear by brazing then re-milling? I do have access to a vertical mill for such purposes, but am a bit wary of attempting to braze the channel.
GregW
I’m pretty sure British Car Specialist has the rivets. There was a thread a while ago about reassembling the window frame. John Loftus was involved in that.
C
Cutlass
Thanks, Greg. I did read that thread. Very helpful. I did a complete restoration of my MGB several years ago, down to the last nut and bolt, but the most frustrating part by far was putting new glass and rubber in the windshield frame. AAARG!
I would like to know whether anyone has attempted a disassembly of the pillar for re-chroming.
John_Progess
I just reassembled my windshield after replating. I was told by the chrome shop that disassembling the posts would be necessary for proper polishing after plating so that is what I did. I got my rivits from British Car Specialists. I made my own tool out of a pair of vice grips for attaching the small rivits to the stainless section and the top hook but for the larger steel rivits I borrowed a rivit squeezer. I did not feel good about just pounding the steel rivits with a ballpein hammer. Have a good day!
John
C
Cutlass
Thanks. The BCS catalog lists the found and braizer head rivets, but not the two flat head rivets. Did you find a source for those?
C
Cutlass
John: The braizer head rivets in my original windshield are stainless steel. The BCS catalog lists the replacements as nickel plated brass. Obviously this would be quite a difference in strength, durabiity, etc. Think that's a problem?
John Loftus
Hi Cutlass,
I found some flat head SS rivets at a surplus store and I still have at least 4 of them if you need them. I did get 6 round head rivets from BCS but didn't use them. BTW, they are steel or SS (they are slightly magnetic which some SS can be)and not nickel plated but have a dull dark grey finish. I guess they could be polished but haven't tried. PM with your address and I'll send them out.
Cheers,
John
C
Cutlass
Thanks, John. However, it takes about fourteen of the stainless rivets to do the job. I'll talk with BCS tomorrow to get their take on it. I can find the right rivets on the internet, but I'll probably have to buy a couple of thousand. Thanks so much for the offer, though.
Speaking of rivets, today I riveted the rear shroud to the boot floor and rail. The car's at the body shop, and they will now be able to put the final color over the new rivets. Pretty cool.
Jerry
group,
Do any of you know of a place that rents the rivet squeezer? A chain store with an office in Sacramento area would be best.
Jerry
M BJ8 Windshield Austin Healey 10
Bob_Spidell BJ8 Windshield Replacement Austin Healey 11
wangdango BJ8 windshield to body hardware? Austin Healey 2
J BJ8 windshield-shroud seal installation-found way to help keep ends from popping out Austin Healey 1
C Re-Chroming BJ8 Windshield Surround Austin Healey 10
O BJ8 Windshield seal Austin Healey 3
H Any tips to install BJ8 bottom windshield seal? Austin Healey 0
J Rechroming BJ8 windshield support posts Austin Healey 5
A BJ8 Upper Windshield Bow - Center Hole Finisher Austin Healey 16
John Loftus BJ7-BJ8 windshield seal cut Austin Healey 6
Ed_K BJ8 windshield frame to scuttle gasket fun ! Austin Healey 10
R Removing 66 BJ8 Windshield frame Austin Healey 23
R BJ8 Windshield Frame Austin Healey 3
J For Sale FREE! 2 fiberglass aftermarket hardtops, supposedly big Healey but NOT BJ8 (close though) Austin Healey Classifieds 0
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
