Ok, for those who are interested, the main horizontal and vertical pieces are extruded brass. The pillar assemblies are just that, appaarently assemblies of machined brass (the chrome plated part), with stainless steel and mild steel parts riveted thereto. The channels are pretty straightforward for re-chroming, but for a proper job I believe that the pillar assembly must be disassembled. The trick there is to find the proper rivets for re-assembly.
One more thing. On the vertical channels, there are four slotted holes for attaching the corner braces. Being brass, some of mine are wallowed out. Has anyone had any luck repairing such wear by brazing then re-milling? I do have access to a vertical mill for such purposes, but am a bit wary of attempting to braze the channel.
