BJ8 Servo
hmj6854
I have a rebuilt original servo in place that is now leaking. Can I upgrade with an updated version? Thanks
Legal Bill
Sure. Buy the brackets as well as the modern servo as the original brackets do not work with the new servo unless you bend one of them and flip the other. Please note that most folks report that the modern replacement does not seem to provide the same amount of boost as the original.
Keoke
Have it rebuilt just stay away from them fruity people-
White Post does a good job.
RAC68
A good while back, I decided to rebuild my Girling servo and was unable to complete the task when I found a crack in one of the unavailable air valves. I replaced the Girling with a Lockheed unit and easily designed brackets to mount the unit onto the same studs holding the Girling. Over the next year I used the Lockheed unit and found it performed passably but provided lass boost then the Girling. Eventually I sourced new air valves and rebuilt the original Girling which has been in place and in use since.
I found the Lockheed produced less assist and found I preferred the added power of the Girling. However, the Lockheed did perform well and provided a good alternative.
A year back, friend was thinking of boosting the brakes in his BN6 and told about the PBRVH40 (https://www.hydroboost.com.au/boostertypes.htm) by a Healey enthusiast out of Hong Kong. A smaller Lockheed look-a-like, the unit used by the Hong Kong Healey owner was purchased on eBay and supplied out of Australia. According to his recommendation, of the 2 single-line models available (VH40, VH44), the VH40 provides a higher brake boost with the VH44 used on disk brake equipped vehicles. Since I found the Lockheed to provide less boost than the Girling, I understand, the VH40 produces quite a bit more boost than the VH44 and details of both units can be found if you Google the unit..
Although I have no experience with these units, I though I would pass on their existence and maybe another forum member can provide additional information.
All the best,
Ray (64BJ8P1)
Jeepster
I wasted hours trying to fit a modern replacement servo and brackets until I finally submitted and had the original unit professionally rebuilt.
It's not worth the hassle.
Keoke
:applause:
In a recent E-mail blast__this week, I'm certain__AH Spares is listing a "new" rebuild kit for the original boost unit.
My own (70%) success rate** not withstanding, might be worth the gamble to see if the short-comings of some of the interim kits have been addressed...?
In fairness, the Internet__let alone YouTube__had yet to be invented when I was actively engaged rebuilding boosters... ;)
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
H BJ8 Exhaust System and Brake Servo Austin Healey 16
R BJ8 with Servo, Is the 7/8 Master Cylinder recommended ?? Austin Healey 7
R BJ8 with servo...Brake travel issue Austin Healey 30
L BJ8 Brake servo Austin Healey 6
C BJ8 brake servo options Austin Healey 5
S BJ8 Brake Servo Replacement Installation? Austin Healey 9
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
