BJ8 Choke Problem
67BJ8
I put new choke cables on my 1967 BJ8. It is tough to pull
out the choke to start the car. I even tried to let oil drip down in the cable before installation. Even pulled out all of the way the car cranks awhile before it starts. Is this a typical problem with BJ8s? My brother in law's 1958
100-6 starts up right now with out even touching the gas pedal. His choke is very easy to pull. What springs are
used to resist pulling out the choke on a BJ8?
Keoke
HI 67BJ8, There are two sets of springs to combat on the BJ8. 1] the throttle return springs and 2] the choke return springs. The springs are identical parts.However, if the choke return springs are not properly stretched the choke will be very hard to pull.Even when properly set the BJ8 choke is a bit harder to set.--Fwiw---Keoke
P.S. There is a potential for binding if the cable is not installed correctly.Correctly meaning no sharp bends. /ubbthreads/images/graemlins/nonod.gif
67BJ8
Where do I get the proper springs and what is the part number? Also, where do the choke springs hook to on the car?
Keoke
HI 67BJ8, The choke return springs are the same part as the throttle return springs which are available from Moss Motors. The Choke return springs hook into the choke return arms at the carbs and then extend directly dowwnward and connect to holes in the chassis,also check the archives we have discussed this recently. However, if you do not have them installed yet and the choke is overly stiff I suggest you check the routing of the cable for tight bends.---Keoke
6 BJ8 Choke Problem AGAIN Austin Healey 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
Patrick67BJ8 BJ8 Choke Cables Austin Healey 5
B BJ8 choke cable Austin Healey 0
N BJ8 choke adjustment Austin Healey 4
6 BJ8 Choke Impossible to Live With Austin Healey 17
Dave Richards Choke Return Springs BJ8 Austin Healey 13
B BJ8 Choke cable - wont move Austin Healey 19
WALTER BJ8 CHOKE ADJUSTMENT Austin Healey 14
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
