Choke Return Springs BJ8
Dave Richards
In piecing things back together, I can't figure out where the choke return springs attach to. Obviously, one end is attached to the cable stop, but to what does the other end attach?
healeynut
Dar100-
The BJ8 originally never had choke return springs on it. Attach the springs wherever it will stick.
If the HD8s are in very good condition and very clean and the car is used every day... you won't need the added choke return sprigns because the jet return spring will be strong enough to work... but that's a long shot if you ask me!
roger_abbott
I encountered this problem when I redid the carburetors on my BJ8. Unfortunately, my springs were too far gone to re-use, so I substituted some look-alikes I found at Ace Hardware, the source of many strange and wonderful items. I hooked them to the bottom of the heat shield, as that is where they were hooked before.
Years ago, I copied the factory parts manual, which included BJ8's to car number 40236. It does not show any return springs for the choke cables. As the chokes will not close on their own, it may be that the factory added "helper" springs. Perhaps there are other listers with better information.
Keoke
Hi Dar100, the pesky choke return springs used on the BJ8 cars are the same as the throttle return springs and must be stretched so they do not add appreciable load to the foot petal while functioning effectively to close the chokes. They were intended to locate in holes on the inner wheel arch at the front carb and on the firewall brace at the back one. These holes may or may not be there and you will need to improvise. The spring can be attached to the eye of the cotter pin where the choke cables terminate at the carb. You might want to use SS cotters as I did.---Fwiw--Keoke
Dave Richards
Dave Richards
Thank you. When I removed the choke cables to remove the carbs, the springs held the cable stop in the hole of the lever, so that's how I put it back.
When I first put things back together, I didn't use the choke springs and the idle was everywhere, putting the springs in, made the car purr, I was impressed. Maybe I'm not anymore, if it means the carbs are dirty, or worn.
I only drove the car about 1,500 - 2,000 miles last year and plan the same for this year, because I drive about 40,000 miles a year for work, and I'm confident my back wouldn't last that many miles in the Healey!
Keoke
No Dar100, it is not necessarily the case that your carbs are worn or dirty. There is a significant amount of friction in the choke's system and overcoming it usually requires the use of the springs. ----Keoke
AndrewMawson
I cannot remember if I left this mod fitted or wether I put on external springs down to the heat shield, but one of my choke return experiments was the long thin springs from a retractable biro threaded over the cable between the outer sheath and the lever. It certainly worked ok.
AWEM
Dave Richards
Dave Richards
AndrewMawson said:
...was the long thin springs from a retractable biro threaded over the cable between the outer sheath and the lever. AWEM
I'm not following...
Keoke
What he did DAR100, was place a unique spring [biro] over the cable end between the cable's support at the carb and the choke lever arm. When you pull the choke it compresses the spring. When you unlock the choke the compressed spring pushes the choke arm back down.--Keoke
Dave Richards
Dave Richards
OK, I guess I better find out what a "biro" is. Thanks, as usual, Keoke.
Oh, like the spring in a ball point pen, the older I get, the less I know!
Keoke
Well Dar100, maybe you not be so old. His modification works very much like the spring in a Ball Point Pen. Very good comparison me thinks---Keoke- /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Keoke
Yes Andrew I know, it was just funny he chose a ball point pen spring as an example I had forgotten about it.--Cheers-- Keoke
AndrewMawson
I have to say it's unusual in my experience to find a 3000 without some form of added return spring. Suprising nothing was factory fitted after a year or two in production.
On my BJ8 I had initially thought that the issue was a hardening of the diaphragm that the jet sits in, making it stiffer, but new jets and diaphragms made not a jot of difference !
N TR2/3/3A 1961-TR-3 Choke Return Spring Triumph 1
H Choke Cable Return Austin Healey 14
Todd78d Bugeye choke linkage Spridgets 5
Todd78d Choke Linkage Photo Austin Healey 0
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
D BT7 Choke Assembly Austin Healey 18
P MGB Zenith water choke gasket needed MG 4
D Choke Cable Length Austin Healey 0
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
L MGB 1977 MGB will only run on full choke MG 53
SherpaPilot TR6 Choke Assembly Triumph 0
M Choke Linkage Austin Healey 3
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
TomMull TR2/3/3A Which choke cable Triumph 12
sparkydave Zenith auto choke coming loose Spridgets 2
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K TR2/3/3A Couple of choke questions Triumph 1
K Choke cable replacement Austin Healey 1
D AH 300O MK1 Choke Knob Position Austin Healey 5
R Jensen-Healey Choke? Other British Cars 1
F TR2/3/3A Choke Cable Problem Triumph 29
F Choke sticking Austin Healey 22
N Enrichener [choke] wire Austin Healey 1
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
F TR2/3/3A Choke Triumph 1
edkap2002 TR6 72 tr6 choke cable Triumph 4
Patrick67BJ8 BJ8 Choke Cables Austin Healey 5
TRMark TR4/4A Choke Cable Routing Triumph 3
S TR2/3/3A choke operation from the factory !!!! Triumph 29
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
S TR4/4A aftermarket choke cable Triumph 3
sparkydave Zenith auto choke coming loose Spridgets 3
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
UmmYeahOk GT6 I Give Up! Help A Millennial Out [Carb/Choke Related] Triumph 28
M TR2/3/3A Choke Cable Detent Device Triumph 11
Rob Glasgow Choke cable turnion Austin Healey 8
TomMull TR2/3/3A Choke on new to me TR3 Triumph 16
L Choke Mechanism 100/6 Austin Healey 26
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
1 TR6 Tr6 needs choke to run good Triumph 11
rjc157 bn7 electronic choke Austin Healey 0
A 1960 BT7 choke location Austin Healey 8
E T-Series MG TD choke cable MG 2
