TR4/4A Baffling Carb Issue
RJS
Hi
I need some help. I spent all day yesterday trying to get my rebuilt carbs dialed-in (SU HS6s). What should have been a 2 hour job became a very frustrating all-day affair.
My issue is a hanging throttle. I got the carbs balanced, mixture set and idle at 750 RPM. But, if I slowly take the RPMs up and let off the gas (i.e. crusing and coming to a stop sign) it will hang at 1,500 to 2,000 RPM. If you snap the throttle, it will drop back to a nice 750 RPM. The car runs great otherwise but, this one issue really spoils the driving experience!
Sitting in the driveway, I can clearly see that the throttle lever on the front carb isn't returing fully closed. With the engine running, I can push the throttle lever back closed with my finger. It only moves about 1mm to close - and it feels like it "releases" almost like something is binding. Idle returns to 750 RPM.
Here's the baffling part - I inspected and checked everything mechanical and I lubed the shafts. With engine off, the throttle lever and throttle disc work perfectly and close fully. It is only when the engine is running that the problem manifests itself. To confirm this, while experiencing the problem (idle at 1,500 RPM), I killed the motor and could watch the throttle lever return that 1mm fully closed as the motor died. Then when I immediately restart the motor, it goes straight to a 750 RPM idle.
At this point, I can only think it is something vacuum related...but what?? I have a new cylinder head and manifold gaskets. Carbs just professionally rebuilt (carb body rebushed and new throttle shafts among other things). Engine has 180psi dry compression across all four cylinders and pulls 20"-22" Hg of vacuum at the intake manifold.
Any ideas?
TexasKnucklehead
With HS6, there should be two throttle return springs (Moss P/N 371-930) -one to each carb lever. Are both springs installed? Is one weak?
charleyf
That is my first guess as well.
Second guess is that on these HS6 carbs the location of the throttle connecting rod ( between the carbs) and the attached levers ( one on each end) is adjustable. Could the lever to the front carb be adjusted so that it is causing this problem? Or maybe adjusted to stop the problem? Two good springs are a must on these carbs.
Charley
TR3driver
Great Pumpkin - R.I.P
Probably not relevant, but I had a somewhat similar problem with my H6 carbs, caused by not getting the stop lever in just the right place on the shaft. There was just a little play left over between the carb body and lever, which was letting the shaft move sideways in the bore when the throttle was open slightly and then the throttle plate would drag on the side as it closed. Somehow the suction from the intake manifold was creating enough friction that it wouldn't slide closed reliably. The sharp edge of the plate had actually cut a small notch in the carb bore.
I wound up cutting a small shim to fit on the throttle shaft, so the plate could be centered with the lever firmly against the carb body.
Tr-Beg
throttle connecting rod ( between the carbs), only the pin need to be engaged and situated at rest in the middle of the fork, the bracket must not touch the carbs, minimum 1 millimeter on each side of the rod. IMO
RJS
RJS
Thanks everyone,
It's definitely not the springs. Been there , done that. Stronger springs only turn the throttle into an on-off switch.
Randall and Tr-Beg I'll try you ideas and report back. Probably not til the weekend.
charleyf
Bob,
The two springs are attached to the lever arms of the butterflies. My guess is that the butterfly is not closing. On my carbs the springs make that closing of the butterflies VERY POSITIVE? A misadjustment of the levers on the ends of the connecting rod could also influence the butterfly movement. Were you able to center the needles during the rebuild?
Charley
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
E MGB SU carb air cleaners MG 10
Healey Nut Tri-Carb Project Austin Healey 213
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
tahoe healey Dumb carb question Austin Healey 23
jfarris TR2/3/3A Happy with my Paltech Carb rebuild Triumph 8
2 TR2/3/3A SU carb. Acts like an expansion valve ! Triumph 10
dbenichou289 TR2/3/3A SU carb linkages Triumph 2
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
O HD8 carb on Healey 3000 Austin Healey 62
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
R TR2/3/3A Carb throttle return spring tension Triumph 2
drooartz MGB Troubleshooting Mikune carb MG 33
