bad compression news
mtlman8
after replacing the head gasket, the car had trouble restarting. I noticed the coil was very hot and since I put a pertronix electric distributer in I figured i'd put in a high performance coil... so far so good. timing correct, oil pressure good... still hard to restart... compression test shows #1 155lbs #2 145lbs #3 75lbs # 4 85lbs...i think at this point I need to pull the motor out and start from scratch and rebuilt it...I would greatly appreciate ANY input from you guys... thanks
tdskip
Oh, and make sure the high performance coil isn't going to fry the Pertronix - you might want to double check the resistance.
TR3driver
Great Pumpkin - R.I.P
Up to you, of course. But pretty much everything having to do with compression can be serviced with the engine in the car (except maybe the camshaft). Kind of messy to replace the liners, but I have done it more than once. And chances are that it will get you back on the road quicker.
Did you check the valves while the head was off?
Does the compression on 3 & 4 come way up with a couple squirts of oil down the plug hole?
M
mtlman8
thanx for all the info. I'll pull the head on monday, check the valves and go from there. i'll be back on tuesday with a report ... again THANK YOU!
M
mtlman8
pulled the head yesterday and had to the head shop by 7pm...intake valves in cyl. 3 and 4 leaked pretty bad.i'll have it back in and running saturday afternoon.with fingers tightly crossed.(going to check the cylinders just to make sure rings are ok.)thanx for all the info guys!
M
mtlman8
pretty happy about needing a valve job:}
M
mtlman8
I got the head in friday, gas tank pulled, cleaned and painted saturday. Today was spent timing the ignition and adjusting the carbs... whalaa!!! niceley tuned motor that runs great!!!! thank all of you for your input. special thanks to bill close and bruce begley. sincerly, one happy man!
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
P TR6 Bad Luck? Triumph 51
jlaird MGB Follow up to my bad post on prewar MGs MG 4
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
T TR2/3/3A bad napa points Triumph 9
S TR2/3/3A Now the bad news. BRAKES Triumph 7
S TR2/3/3A How bad is this? Vertical link Triumph 12
Alfred E. Neuman TR4/4A Bad news on my TR4 Triumph 8
D TR2/3/3A Bad parts. Triumph 16
charleyf TR4/4A Symptoms with bad condenser Triumph 14
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
W TR2/3/3A Overheating Bad Triumph 12
roscoe Good news/bad news Austin Healey 11
Rut Help a bad memory out... Spridgets 6
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
C TR6 Frame Pics, some bad news Triumph 9
M TR6 Fresh rebuild gone bad!!!!!!! Triumph 13
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
TR3TR6 TR2/3/3A Anybody else having a bad day! Triumph 31
S Is it a bad idea to buy a higher pressure radiator cap? Austin Healey 47
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
gbtr6 TR6 Good news, Bad news Triumph 10
JFS TR2/3/3A Bad Water Pump Triumph 11
P TR2/3/3A "MaXpeedingRods" con rods good or bad? Triumph 3
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
D Removing servo . Good or Bad Austin Healey 12
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
Sixpack TR6 Bad Oil Leak Triumph 24
tinman58 TR2/3/3A Bad thinking? Triumph 25
Geo Hahn TR2/3/3A Bad Day in the Garage Triumph 23
tinman58 General Tech Bad spark plugs Triumph 7
J The Good the Bad and the Ugly Lotus 4
DanLewis How bad does your Bugeye need a boot? Spridgets 6
bighealeysource How to color sand really bad orange peel Restoration & Tools 6
D Spitfire '65 Spitfire MKII w/bad vibes Triumph 4
T is my generator bad? Austin Healey 5
T TR2/3/3A Sticker idea; good or bad? Triumph 11
pkmh Distributor rotor gone bad more than once. Austin Healey 5
PAUL161 Moss Motors T Series Parts - Bad Gaskets! MG 5
Boggsy64 MGB Brit are bad engineers MG 17
M My '65 suddenly started running bad today Spridgets 37
HealeyRick Bad Day on the Hill in NZ Austin Healey 7
S TR2/3/3A Bad fuel perhaps water tr3 miss Triumph 0
bertl Bad Surgery Triumph 7
J Bad News 1098 Spridgets 14
John_Mc Probably just a bad ground somewhere... Triumph 1
I Effect of bad valves on engine performance? Triumph 9
J How bad do Spridgets leak oil from the crankshaft? Spridgets 18
