And now for a question along a different line.
regularman
I have never been to a car show, but in some of the pictures that I have seen of car shows online I have seen spridgets with hitches to pull a small trailer behind. Has anyone here seen one of these or do you have one. The reason that I ask is this. My dream has been for a long time to be able to pull my small sailboat with the midget. The boat weighs about 320 pounds and the trailer about 150 pounds. Its less than 500 pounds to tow all together and very little tounge weight. The boat is (as you can imagine very aerodynamic) as well. I need to find a picture of the boat, aptly named "Miss spridget". I have worked on and made some hitches for trucks and things but I don't know what to bolt a hitch to on the midget. I would appreciate any info on this. I know that some people with LBCs pull a trailer just to have spare beakdown parts and to haul stuff to trade etc at car shows.
Atrus
I'm curious on this too, as it would be cool to put luggage/spares in for a trip. Just a really small trailer. Heck, I've seen pics of a big healey's back 1/3 made into a trailer where the boot is the storage area. I think something like that on a trashed spridget would be cool - weld in a front panel behind where the front seats would end and use the back half.
jlaird
Easy trick on a bugeye. steel plate 1/4 inch drilled for the bumper bolts under the rear pan. There are two each side.
Weld a tounge for the ball to this plate.
Pulled a sunfish for years in Hawaii, no problems.
500 pounds should not be a problem at all, just be careful with stoping distances.
You may be able to make support plates inside the trunk that go from the rear spring mounts. This is a 1971 Midget... right?
regularman
regularman
I was thinking of using the removable hitch type so that there would be nothing sticking out when not towing. Is there any difference between a BE and the later model spridgets with where to bolt up. I would really like to see a picture. I'm not quite picturing what you are saying Jack.
jlaird
How about a plate in side the trunk and outside behind the tank through bolted?
regularman
regularman
Ah, now I could do that. Put my hitch reciever on the underneath plate and just a falt plate inside the trunk. It would be bad to get hit and have that hitch driven through the gas tank /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
derf
I have a very good donor RB body tub. The front 1/3 of the car is trashed but the rest is good. I'll be taking the rear end and driver's floor pan out. But, the rear 1/3 would make a good trailer.
regularman
regularman
Here is a picture of Miss spridget on the water. I don't have a picture of her on the trailer.
jlaird
Haha, let them prove otherwise.
Billm
Long ago I had a hitch on my MkII (non-removable type). I ran a piece of steel angle (1 1/2 x 1 1/2 x 1/8) between the bumber supports and the bumper and hooked the generic hitch (from an old Merceedes or something) from the angle and bolted the long end under the car using some 1" long spacers. Towed a Force 5 sailboat for years to Mission Bay in San Diego for years.
Bill
JPSmit
From owners manual (1500)
says towing capacity is 1,344 lb (610kg) recommended downward load on hitch is 75 lb (34) kg.
also says a 1 in 8 hill can be ascended in first gear with this weight.
go figure
12.5 % grade requires first gear? Interesting.
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
B TR4/4A Jaeger Gauge Question Triumph 16
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
R TR6 Starter wiring question Triumph 6
K TR2/3/3A TR-3B carb question Triumph 13
