aluminum radiator
Murray
Member
Does anyone know where to buy an aluminum radiator for a TR3? I know TRF sells them but there must be other suppliers.
Thanks,
Murray
TR6BILL
I think that Ron Davis Racing in Arizona will make you one up. I have one of theirs in my TR6 and have no complaints. On the higher end of cost, but not by much.
Number_6
Thanks,
Murray
Here are a couple of places that were recommended to me when I was considering a aluminum radiator for my TR3 last spring:
The first site Wizard Cooling doesn't show it on their site but I emailed them and they do sell one. Last April they said the radiator with electric fan and brackets would be about $620.
Wizard Cooling
Also TRParts has them for about the same price of $625 with electric fan and brackets or just the radaiator for about $425.
TR Parts
BobbyD
I got mine Wizard Radiator from Art Lipp at the TR Parts link in Number 6's post. Art lives right near the Wizard factory and has a great relationship with Scott the owner. They both provided me with terrific customer service when a small problem popped up. One of the guys on the 6-Pack forum actually had Wizard engrave their logo upside down from how they normally do it. That way, when the TR6 hood is opened, the logo reads right side up. Not too many companies will do that for you! I got the radiator and Spal fan combination and everything works great.
Brosky
That was me who had the logo done my way (with NO hassle from Art or Scott) and I ditto Bob's comments.
Number_6
After seeing the way that your radiator looks with the Logo done turned around I would think that they would start doing them all that way for the TR6 radiators. It makes more sense that way, the way they do them now, the logo look upside down on a TR6.
PATR8
Woody sold me one for my 8 that was custom made from Griffith in South Carolina. I am very pleased with it so far but I am not sure I think in the long run it was worth the money. I was worried because in traffic in DC my 8 was running 3/4. After I swapped the radiators I found my fans were running 3/4. I fixed that and now my car runs at 1/4.
DNK
Major- Is yours carbed?
I can't recall.
philman
I just had the radiator rebuilt for my TR7v8, I went with bigger tubes and more spacing. The radiator guy said more flow that way and better cooling. I haven't tried it though. He is usually spot on with radiator questions, I can drop a radiator off and he knows exactly what model car it came from.
newmexTR3
Wizard Cooling is the way to go.
Martinld123 Aluminum Radiator Leak? Austin Healey 3
SherpaPilot TR6 New Aluminum Radiator Triumph 4
thechileman TR4/4A New aluminum Radiator Triumph 4
tinman58 TR5/TR250 Aluminum Radiator Triumph 3
drooartz MGB Ron Davis aluminum radiator, notes from my install MG 7
P Aluminum replacement radiator Austin Healey 7
DanLewis Taking a chance on a Chinese-made aluminum radiator for my Bugeye Spridgets 74
BoyRacer Aluminum radiator Austin Healey 40
G Aluminum Radiator Triumph 16
M TR2/3/3A TR3 Aluminum Radiator [Wizard] Triumph 18
M Aluminum Radiator Spridgets 7
CharlieCarpenter Aluminum Radiator Austin Healey 28
B Aluminum Radiator Spridgets 18
wkilleffer Recoring a radiator in aluminum MG 20
Lin Aluminum Radiator Baffles Austin Healey 8
V Who uses an aluminum Radiator? Jaguar 17
G Ron Davis aluminum radiator and Spal fan pics..... Triumph 9
G Got my Aluminum Radiator in......now what? Triumph 5
sim 948 aluminum head gasket Spridgets 2
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
J Best Aluminum Fenders? Austin Healey 3
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
Healey Nut Aluminum doors Austin Healey 7
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
nichola TR6 Aluminum block engine Triumph 8
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
R Proper Aluminum Sump Installation Austin Healey 13
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
I TR6 Aluminum trim ring band removal Triumph 5
I TR6 How to distinguish between stainless and aluminum Triumph 6
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
R General Tech Aluminum oil gallery plugs Triumph 3
T TR2/3/3A Iron or aluminum plug in top of head? Triumph 2
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
Griz Aluminum door trim Austin Healey 5
B TR4/4A Aluminum head water leak? Triumph 7
maxwedge5281 aluminum fender vents installation Austin Healey 14
JFS Wedge Aluminum Rad Triumph 16
Nunyas what to use on polished aluminum Restoration & Tools 4
