AIR CONDITIONING IN A BIG HEALEY
bighealeysource
Bronze
Hey y'all,
I know, put the top down but was curious if anyone knows
if there is such an animal available out there. I remember
a friend of mine got a 1967 BJ8 when it was new in 1967
and had A/C installed by the dealer. Of course he had
money and I was driving a Ford Falcon but that's another
story. Moss makes a kit for the MGB but never seen anything
for a Healey. Any ideas ?
Thanks,
Mike
mrdibbles
Member
I love AC too. I had a 1965 Mustang convertible with AC and I loved it to death. Don't take grief on this... you ar not alone! (Although you and I are in a very small minority).
Cottontop
Follow this link. A/C in a Healey
Bret is a member of the North Texas AHC and has recently air conditioned 1/2 dozen or so cars.
Tim
mjobrien
I Believe that Paul Tsikuris in Lakeland Fl. has done a few of these as well...
Patrick67BJ8
bighealeysource said:
Hey y'all,
Thanks,
Mike
What you saw in '67 was probably the 'Factory Approved" AC made by Coolaire in Miami, FL. They made a lot of AC's for British cars. The original units can still be had but are extremely hard to find. I had one installed in my car back in the seventies and sold it a few months ago. I converted to a under the dash installation from Bret Blades of Blades Design in the Dallas, TX area. His installation has a bracket for the "rotary compressor" and an American alternator that replaces the from Generator bracket. The only way to go! Parts of my installation is on photobucket.
Patrick
Ed_K
After reading this, I see a major wintertime project in my future.
Does the under dash evaporator box also contain the heater core ?
Ed
bighealeysource
bighealeysource
Bronze
Thanks everyone for the info on A/C in a Healey. I already
e-mailed and got some info from Bret Blades in Dallas and
since I'm on the east coast, may try to speak to the
fellow in Florida. Now to see if I can afford this project !Regards,
Mike
Coastalman
Mike,
Please keep us updated. Being on the east coast and knowing at least one other member who wants A/C, I am very interested in what you find out is available close to us.
Charlie
Lin
Hi Gang,
The images at this link show what I think is the best installation of air conditioning controls and venting in any Healey interior I have seen. Although I am not sure, I believe this is Bill Naretta's car. I think you will agree that it is a beautiful job. I have no idea how well the system works, but it sure looks good!
https://homepage.mac.com/linwoodrose/PhotoAlbum69.html
Lin
1960 BT7 "The Bloody Beast"
1959 AN5 Bugeye
Patrick67BJ8
Ed
The original heater core is removed and replaced with a combination unit.
If you went to photobucket.com and enetred <pyoas>, it will take you to a page that will allow you to find my installation. I have captions listing everything used. I have replaced the original factory condensor since the photos.
I installed two vents in the center where the speaker grill is. They are 2.5" and will be replaced with 3.5" vents. I also installed a vent near each door opening and thios really helps throw the cool air across the whole width of the compartment. The hoses that connect the center and outer vents will get a "Y" vent in between them that will direct AC or heat to the feet areas.
The heater really works nice and even across the whole inside. Same goes for the AC cool air. I measured 44 degrees coming out of the center vents! An thermostatically controlled electric fan in front of everything takes care of any engine temp. The fan also works without the AC turned on so it does double duty.
I have seen brackets that attach to the generator bracket for other AC installations and I went with Bret's because it is much stronger and "clutter free". It's hard to image hanging a compressor <span style="text-decoration: underline">and</span> alternator off the small origianl generator bracket "ears" and it lasting long or a simple overtightening or missing spacer washer cracking the original bracket. I went with what I thought was the best.
Patrick
Jerry
Bret's hangers work very well. I have noticed that my Alternator hangs too close to the top radiator hose. I am still trying to fix that . Bret says he has changed the bracket slightly to tilt it towards the outside of the car. This should eliminate that problem. The bracket is made of 1/4 inch plate. Very sturdy. It was easier to fit it with the engine outside the car. I did use a few washers here and there to get all the play out of the compressor and alternator. It is very solid and accessible once installed.
Jerry
BJ8 (air conditioning in progress)
bighealeysource
bighealeysource
Bronze
Hey Charlie,
Will do ! Just starting to look into this and got great ideas from everyone.
Too bad Moss wouldn't offer a kit for Healey's like they have for MGB's.
Regards,
Mike
Lin Pulley and belt configuration for air conditioning Austin Healey 2
drambuie Air conditioning your Healey [Great installation] Austin Healey 10
I General air conditioning questions Triumph 4
justin_mercier Wedge TR7 Air conditioning help / books/ manuals? Triumph 16
T Air Conditioning Temperature Jaguar 2
T 1989 XJ6 air conditioning Jaguar 1
DNK Air Conditioning Going Bye-Bye Triumph 5
jjbunn Air Conditioning MG 15
AUSMHLY Air conditioning in a Healey...see photo Austin Healey 30
P 92 XJS Air Conditioning Questions Jaguar 8
mgbmedic MGB MGB Air conditioning MG 30
T Wedge TR8 air conditioning parts?? Triumph 3
Webb Sledge Air Conditioning? Triumph 78
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
Carlbanan56 MGB Puling air MG 5
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Celtic 77 MGB Tinny Zenith air regulator MG 0
Celtic 77 MGB Seized air pump issue MG 25
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
D BT7 Air Vent Control Cable Routing Austin Healey 0
DrEntropy MGB Air filter MG 16
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
F TR4/4A Replacement air filter for SU HS6 Triumph 6
A MGB MGB flap and air box MG 60
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
tahoe healey Cooper Air Filters Austin Healey 7
petnatcar Air Scoops Behind the Grille Austin Healey 0
D Wire Wheels and Air Leak Austin Healey 16
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
PC air back there... Spotted 0
equiprx Air Compressor Moisture mitigation Restoration & Tools 17
S TR2/3/3A restore my original air filters Triumph 5
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
E MGB Oiling foam air filter MG 3
E MGB SU carb air cleaners MG 10
RAC68 Cold Air Bilge Blower update Austin Healey 13
P TR6 New front shocks & air in clutch Triumph 15
N Air filters Austin Healey 5
M Cooper's Air Filter on H1 Carbs Spridgets 5
TomMull Scroll Air Compressor Restoration & Tools 13
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
M TR6 Tr6 fresh air vent replacements Triumph 1
