Adjusting Valves on TRactor Motor
martx-5
I adjusted the valves on my TRactor motor (engine rebuild) using the "Rule of Nine". However, I noticed that I had excessive valve lash on the exhaust valve on #1 cylinder when the engine was at TDC. I checked some others, and it was the same thing. I have a reground cam in there (282 deg. duration), which I think is causing this problem. If so, what is the best way to adjust the valves, because the "Rule of Nine" does not seem to be working.
BTW, I broke one of the adjusters tightening the lock nut, so I'm going to replace them all and start over again. :eeek:
And what's with the new way the smilies are arranged? :crazyeyes:
martx-5
martx-5
Geo Hahn said:
Are you saying that the gap on #1 exhaust was greater at TDC than what you set it to when #4 exhaust is fully open?
My mistake, not the exhaust valves, the intake valves. :blush: #1 intake valve lash (2nd valve) was greater at TDC (for #1 piston) then when #4 intake valve (7th valve) was fully open. Does that make sense??
Edit: Or am I misinterpreting the "Rule of Nine"??
Geo Hahn
You have interpreted the the 'rule of nine' correctly. I'll let someone with experience with modified cams chime in on whether this is a symptom of longer duration.
I would probably just set the lash with the cylinder at TDC on the power stroke but maybe it isn't that simple.
TR3driver
Great Pumpkin - R.I.P
I'd double-check your data ... but if it's correct, I think your cam is incorrectly ground. The symptom is known as "base circle runout", and Crane says it should be less than .002".
AweMan
I dun know about y`all, but I adjust each and every cylinder to specs cold at T.D.C. one by one. Then fire it up, warm it up and adjust em all again while the engine is at idle speed and at operating temp. I know, old school, but it is the way I was taught. {that`s a solid lifter engine}. For hydrarolic lifters each and every cylinder individualy at T.D.C. to zero lash and whatever the specs are
eg.
additional 1/2 turn or 1 1/2 turns ect.
with hydrolics I don`t bother with the warm up adjustments.
martx-5
martx-5
Well, since I'm going to change all of the adjusters due to the fact that I broke one, I start afresh. I'll adjust the valves first by bringing each cylinder up to TDC on the compression stroke, and then see how they pan out using the "Rule of Nine".
TR3driver
I always just do TDC myself; easier because you only have to turn the engine 4 times instead of 8. Easy to see, too, just look at the valves for the opposite cylinder in the firing order. If it has both valves moving, and they are nearly the same opening, then the cylinder is very close to TDC. And if one cylinder is at TDC between intake & exhaust, then the opposite cylinder is at TDC between compression and power (for any even fire 4 stroke engine).
But since I've only got a spec for clearance cold, that's the way I set them.
T Adjusting valves makes me more crazy. Triumph 18
Y TR4/4A Adjusting valves on a TR-4 Triumph 4
vping Need help adjusting valves MG 29
F Turning your engine when adjusting your valves ? Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
AUSMHLY Adjusting Valve Clearance Austin Healey 31
S Testing and Adjusting procedure for RB340 Austin Healey 4
doc50 Adjusting play on steering box? Other British Cars 5
T Adjusting windows/tops etc. for comfortable highway travel Austin Healey 10
BN6_2197 Adjusting Rer Brake of BN6 Austin Healey 2
BN6_2197 Rookie question on adjusting valve clearance Austin Healey 9
Jim_Gruber Adjusting Spridget Doors Spridgets 4
Tinkerman TR2/3/3A TR3 A 1960 adjusting apron Triumph 4
drooartz General MG Alternator link - adjusting bracket length on MGB? MG 8
Joe Reed MGB Adjusting the reverse lamp switch... MG 3
vette Adjusting HD8 Carbs Austin Healey 21
M Adjusting Front Suspension Austin Healey 11
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
Geo Hahn TR2/3/3A Steering Box Adjusting Screw Triumph 12
RJS TR4/4A Setting up Self Adjusting Slave Cylinder Triumph 6
Jim_Gruber Adjusting Pushrods in Pedal Box Spridgets 5
B Adjusting SU-HD6 Carbs Austin Healey 2
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
S TR2/3/3A little adjusting screw tr3 Triumph 1
F Adjusting gear lever, centershift 3000 Austin Healey 2
L Adjusting the bows before top installation Austin Healey 2
bighealeysource Adjusting toe in on a Healey Austin Healey 8
M Adjusting TR3 regulator Restoration & Tools 1
Scotsman Adjusting clutch pedal travel Triumph 2
R Adjusting Valve Clearances Triumph 13
Moseso TR2/3/3A Adjusting Koni shocks [TR3] Triumph 10
N Adjusting headlights on a BJ8 Austin Healey 2
A Adjusting BJ8 Doors Austin Healey 5
K TR2/3/3A TR3 Fuel Gauge Again.....Adjusting? Triumph 11
B TR2/3/3A 57 TR3 BONNET ADJUSTING SHIMS Triumph 4
drambuie Adjusting steering box with shims Austin Healey 6
brgrmyster TR6 Adjusting TR6 Headlights Triumph 8
M Adjusting idle speed Triumph 28
bighealeysource adjusting the handbrake on BN6 Austin Healey 1
TR6oldtimer Adjusting rockers Triumph 7
Darwin Adjusting steering play? Triumph 7
hondo402000 TR6 adjusting windows to Wind screen TR6 Triumph 2
wangdango 100m bonnet fitting/adjusting?? Austin Healey 4
JohnnyMead Tips on Adjusting the Clutch Slave Pushrod? Triumph 4
pjsmetana Low Idle, DVG adjusting = no dice Triumph 12
