TR2/3/3A 83 to 87mm Piston Considerations
Joel M
When going from 83 to 87mm pistons, what modifications (if any) are required in parallel to ensure a good running engine? I would like to keep the intake manifold original and not chamfer or port the head, but am concerned this might be too restrictive for the increased capacity. I understand the higher compression ratio will result in increased heat and premium fuel may be required, but other than that are there any real concerns? FYI, I have a 3A with an early high port head. I do plan to convert to an electric fan/alternator/narrow belt, but everything else will be original.
Just a quick background - the engine was rebuilt about 15 years ago with 87mm pistons and setup on the frame without the body. It seemed to run hot during initial startup back then, and the engine has not ran since. Due to sitting such a long time, I recently disassembled to clean. If multiple other modifications will be required with the 87's, I will probably just get new liners and rings for my original 83's.
Joel
TR3driver
Great Pumpkin - R.I.P
I've installed 87s with no other changes. Ran fine, no more overheating than with 83s. Unless there is some other problem, you should be fine. Yes, the stock manifolds won't give you all the power you could possibly get, but they will work well enough. Don't forget, the TR2 originally had smaller carbs and a more restrictive head (with 83mm liners).
tomshobby
I installed 87mm liners and pistons in my 64 tr4. It still my favorite car ever.
Geo Hahn
Me too - from 83 to 87 in a TR3A. Nothing else changed, it's all good. I still run regular gas and get no problem pinging. Never overheated before or since.
...I understand the higher compression ratio will result in increased heat and premium fuel may be required...
Does this change increase the compression ratio?
TR3driver
Yes, a little, at least with the sets I've had. The larger bore gives you more displacement (each cylinder goes from 498cc to 547cc), but the 87mm pistons have the same height and flat top as original 83s. So the compressed volume remains substantially the same.
Compression ratio is (displacement + unswept volume) / (unswept volume), so if displacement goes up and unswept volume doesn't, the ratio goes up.
I can't find my notes from measuring a stock TR3 head (and they weren't all the same anyway); but if we assume the 8.5:1 number is correct with 83s and work the equation backwards, the unswept volume comes out 66.4cc. That would make the new CR 9.24.
J
Joel M
Thanks for the feedback all. I will just reuse the 87's.
I do have a somewhat related question. The County pistons have 4 very rough holes below the oil ring, that appear to be covered from inside the piston. Does anyone know the reason for these holes? The look of them makes me question the quality of the pistons, and wonder if they will last long term. I have only rebuilt a few different engines, but have not seen this anywhere else.
CJD
Those holes are likely not blocked. They go up to the back of the oil ring, so that oil which is scraped from the cylinder by the ring is transferred lower down the piston skirt for lubrication. Sometimes they will just go inside the skirt to reduce/increase the amount of oil on the cylinder wall. Those pistons are just fine.
J
Joel M
That makes sense, although I don't understand why the holes look like they have been busted out. What kind of manufacturing method is that? I guess one that is cheaper than just drilling a clean hole.
J TR2/3/3A 87mm piston ring gaps Triumph 15
M 87mm piston n liner Triumph 1
T TR2/3/3A TR3A engine - who has the best 87mm piston set Triumph 8
L TR4/4A Looking for a TR3-4a 87mm piston & Liner Triumph 0
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
S TR2/3/3A if it is 86mm or 87mm. Triumph 7
T General TR Ever wonder why 87mm is a favorite size? Triumph 6
K TR2/3/3A TR3 83mm Cyl Liners bored out to 87mm? Triumph 2
H Anybody here running 87mm pistons+cylinders Triumph 6
S 87mm pistons and liners, are they all the same? Triumph 2
M TR4/4A 86mm vs 87mm liners/pistons - TR4 Triumph 2
P Best Carbs with 87mm liner kit Triumph 8
K TR2/3/3A Piston slap? Triumph 3
T TR2/3/3A valve guides and piston clearance Triumph 6
Simmo TR2/3/3A Something is eating away at my Piston Liners Triumph 15
D Separating the piston from the connecting rod. Spridgets 9
J Piston Coating Austin Healey 3
KVH General Tech Grant Piston Rings--Can't Fit Them Triumph 15
KVH General Tech Removing Piston Wrist Pin Triumph 2
sail TR4/4A Piston Ring Question Triumph 6
M Wanted WANTED...New TR6 piston set. Triumph Classifieds 2
K TR2/3/3A Brake caliper piston install? Triumph 18
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
Jayplum TR2/3/3A TR3 Piston Sleeves Triumph 36
M TR2/3/3A How many miles to seat piston rings? Triumph 4
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
BJ8Healeys Disc brake piston seals Spridgets 2
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
M TR2/3/3A Please Help ID This Piston Triumph 6
Got_All_4 TR6 Are these piston nitrated coaded Triumph 5
Gerard 1275 piston ID Spridgets 2
HighAltitudeTR3 TR2/3/3A Piston Slap 👋 Triumph 12
M TR2/3/3A Sleeve and Piston Sizes Triumph 6
Got_All_4 TR6 Depth of the metering needle in the air valve piston Triumph 12
steveg Piston options for Healey Austin Healey 12
T TR2/3/3A SU Piston Drop Test Triumph 4
C TR2/3/3A Piston gap orientation Triumph 2
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
AHS TR4/4A Looking for piston & liner recommendation Triumph 17
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
T General Tech Brake caliper - piston stuck Triumph 4
2billydavies TR2/3/3A need an educational lesson about piston rings Triumph 14
KVH TR4/4A Piston Size Measurement on Rebuild Triumph 4
Jake OD unit operating piston rings? Austin Healey 1
JPSmit Brake piston removal - McGyvered some tools Restoration & Tools 0
W TR2/3/3A Piston and Liner Triumph 2
tinman58 TR6 Piston clearance Triumph 4
T TR4/4A Overdrive piston is sticking Triumph 9
TomMull caliper piston tool Restoration & Tools 11
