5spd Conversion Question
There are people that import the kits (including rebuilt type 9 trannys) but they expensive. Try quantum mechanics.
M Supra 5spd conversion complete Triumph 21
P 5spd Trans for Bugeye Sprite Spridgets Classified 14
64rocksprite Datsun 5spd & Rivergate Spridgets 5
lbc_newbie Datsun 5spd in MI for $200....comes with car Spridgets 4
mgblue79 Another thought on the 1500 5spd... Spridgets 6
G Wedge TR7 5spd Triumph 2
AndreL TR6 Conversion to electric fuel pump Triumph 10
mctriumph TR2/3/3A Ultimate fan conversion Triumph 10
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
zoohow TR6 Carburetor Conversion kit Triumph 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
R Smitty Toyota Conversion Angle Drive Austin Healey 16
P Positive to Negative Conversion Austin Healey 1
P Pos to Neg Conversion Austin Healey 1
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
D transmission conversion Other British Cars 1
W TR2/3/3A Wire Wheel Conversion Triumph 5
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
petnatcar Breather Hose Conversion Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye disk brake conversion Spridgets 10
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
C TR2/3/3A Rack and Pinion Conversion for Tr's Triumph 0
Walter74 Throttle Cable Conversion Austin Healey 6
PAUL161 T-Series Dynamator Alternator conversion. MG 23
M Dynamo to "Dynamator" Conversion Austin Healey 2
S Stag Lucas 18ACR alternator conversion Triumph 5
H Shock absorber conversion Austin Healey 3
S MGB MGB engine conversion MG 27
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
J TR6 Moss HS6 SU conversion kit question Triumph 4
roscoe 5 speed conversion question Austin Healey 9
maxwedge5281 bought back my first nasty boy conversion!! Austin Healey 6
I Bug eye front disc brake conversion. Spridgets 5
steveg Cost of V8 conversion Austin Healey 34
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
M TR6 5 speed conversion Triumph 33
C AUF214 solid state conversion question British Motor Corp 0
I TR6 TR6 EFI Conversion Triumph 19
