Assuming that it is the same as my '74 that I had appart last year, the switch is rather unique. It has a single power lead that is switched to power the other circuits at once...I recall once line each to the the rear signal lamps, one for the front lamps a another for the side markers. I woould suggest the following steps:
-Using a continuety tester, find the pole that should be the power and see if it has a closed loop when the switch is in the on position...then test each of the other connections to make sure they have the same reading.
Changing the switch is not really that difficult...unscrew the screws holding the plastic console to the metal frame (two on each side of the radio mount) and pull the entire assembly, radio and all, forward enough to get a hand into the back of the switch, release the retaining clip and pull it out.
Of course, the new switch is installed in the reverse order /ubbthreads/images/graemlins/grin.gif
