1275 Water bypass nipple
erstearns
Bypass nipple on the underside of the head is broken off flush. Tried WD40, heat and "easy" out with 4 foot cheater to no avail. Anyone know what the thread is on the nipple? Seems to be sort of 5/8 but with a thread between fine and regular. If I can find the right thread chaser I can drill and clean out the threads. Otherwise, any good ideas on how to seal it? Weld patch, bash in a copper or brass plug?...... :madder:
spritenut
Many are corroded off or beyond use.
I do not remember the size of the threads but it is a basic plumbing fitting that I bought at the hardware store. (not home defect but a real hardware store)
Maybe a 3/8 pipe nipple.
mightymidget
I found that if you cut the wall of sleeve with a small metal saw, it releases pressure so part can be removed without thread damage. if you cut to far it just puts a line in the threads. I have not tried it in the area you are talking about tho
Spridget64SC
Thread is 3/8" BSP, British Straight Pipe. Not tapered and doesn't match with SAE stuff. Matches with some JIC/plumbing and AN type threads. MM's suggestion is a good one. Use a Dremel tool and cutoff wheel and then a punch and hammer to curl the piece into the bore. Probably can drill with a 1/2" on the drill press to thin a bit more. I usually drill with a 9/16" on the mill and then thread for a 3/8" NPT plug since I'm usually doing this for racing purposes. If I've centered really well on the hole, the 9/16" drill will cut everything out and leave the threads in good condition. Just a cleanup with a dental style pick.
HTH,
Mike Miller
These are really hard to remove when not broken off, and I never gotten one off without using heat. When they are in whole, I use a pice of dowel to put into the ID, then I grabbed REALLY tight with a pair of vice grip, and use a fair amount o heat, and pentrating lube, and be patient.
Since your is broken off flush, I's do what Mike says and keep drilling it out with larger drill bits. We don't even run thm on the race cars, we either use a water pump that the bypass is undrilled or we tap the bypass in the water pump to 3/8" and put a bolt in it, then use a plug on the cylinder head, the Copper S 1275 head did not run the byass from the factory, those head just have a big brass plug in the head.
E
erstearns
Will try the wax and heat..... tried heat and WD40 to no avial. If that does not work will drill out with 1/2 and 9/16 and tap with 3/8 iron pipe thread tap. If all else fails can drill threads out and pound in a copper plug. Any suggestions as to which type to try? Have seen cup type that looks similar to standard copper type cap but tapered for hight pressure fluid sealing.
Eric, just be patient, that fitting is without a doubt the most difficult thing to remove for a A series engine.
dklawson
Hap Waldrop said:
the Copper S 1275 head did not run the bypass from the factory, those head just have a big brass plug in the head.
I have one of the first 500 1275 -S engines. It came with the AEG163 head and it has the bypass nipple. When I rebuilt the engine I installed a later big-valve head based on the 12G940 casting. It also had the bypass nipple. I thought it was not until they went to the A+ block that some of the heads were built without the bypass nipple.
Regardless, I have an acquaintance who uses almost the same method as you to remove the nipples from the head.
nomad
If you know how to grind an engraving graver I have a couple of homemade tools for this kind of job. Made out of old triangluar files. I would cut thru to the threads 2 cuts approximatly 60 degrees apart. Then use a good punch to drive the small segment out. Use the punch to loosen the remainder and it should screw out easily. Just my technique!
Kurt.
E
erstearns
Being somewhat impatient.........I drilled out the aluminum with a 12" 1/2" bit. The chuck of the drill was up against the crank, as it drilled in it offset some and I was left with some aluminum on one side and engine block on the other. It was smooth and since there was no way the alum thread was coming out without some real effort I went ahead and tapped with a 3/8" pipe thread. Gobbed on some thread sealant and screwed it in. Fingers crossed.....hope for no leaks.
M 1275 need to install water temp bulb. Spridgets 6
GB1 1275 Water Pump Pulley Spridgets 3
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
Jim_Gruber 1275 Damper Pulley Needed Spridgets 16
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
Gerard 1275 piston ID Spridgets 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
