1275 midget equivalent replacement radiator
recordsj
Does anyone know of a good equivalent replacement (i.e. a radiator from a differnet car, maybe a more modern one that is easier/cheaper to obtain) radiator that will fit into a 1974 midget (as opposed to buying a 1275 midget radaiator from Moss or VM)?
Rut
I believe there's a VW radiator that fits well, but I can't remember which one. Hopefully someone will be along pretty soon who knows.
Rut
R
recordsj
If anyone has a link to a good website that shows what is needed to be done in using a different radiator, please provide the link also.
JOeyKnapp
Maybe search for people who have done rotary swaps, or otherwise. Those guys seem to end up using different radiators..
Rut
Use the advanced search function, select spridgets, type in vw radiator, 1 year and search. Numerous threads on the subject.
HTH, Rut
Jim_Gruber
Take a look at Sprite Spot Forum. Frank C provided details on using a Geo Metro Radiator. Pics are there. Automatic Version is the one you want. This one os also available in a 3 Row version. It's something like 12 x 12 in size.
Jim_Gruber
Look under Cooling Section
R
recordsj
correct I have a 1500 (the car is a 1974 with a 1500 that a previous owner installed with a spitfire OD).
Jason
bill_powell
Understood; BTW, I have read on several occasions that the Metro is a good option.
On my 1275, I ended up installing an aluminum unit from Champion radiator; no complaints. In fact, it's been a great radiator. Cost about $140 shipped, if I remember right. Bought on their eBay store.
Here's a thread discussing Champion's radiator:
https://www.mgexperience.net/phorum/read.php?3,1981675,page=1
I do not know if they carry one for the 1500, but you never know. If you want, give 'em a call and see. Here's their website:
https://www.championradiators.com/
Either way, good luck on the project!
Bill
nomad
Jason
Always wondered if the Spitfire OD trans setup would fit! Why did'nt the factory offer it?
Kurt.
JPSmit
nomad said:
Jason
Kurt.
it will but the transmission tunnel needs to be massaged - which is why (I suspect) it was never offered.
R
recordsj
with a 1500 engine in a 1974 mg midget that has a 1275 radiator with a cowl for for a 1275, anyone know if a 1500 radiator would fit into the 1275 cowl?
Or does anyone know if the 1500 radiator is the same size as the 1275 (other than possibly the inlet/outlet)?
With having a 1500 engine should I have the 1500 radiator (in other words does the 1500 radiator have a better matched capacity for the 1500 engine than the 1275 radiator)?
nomad
It is bigger and it will fit but you may not be able to use your heater air inlet since it offset's to the right of the car. That may not be a concern for a 74 since, I believe they may have had the heater change anyway. Of course radiator hose's and such will have to be routed.
Kurt.
D MG Midget 1275 rear oil seal. Spridgets 0
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
A For Sale Sprite/Midget 1275 clutch cover. Austin Healey Classifieds 0
jmayzer 1275 Midget Bentley Shop Manual Download Spridgets 1
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
M Wiper motor connector removal - 1275 Midget Spridgets 4
F MG Midget 1275 oil leak Spridgets 7
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
K 1275 Midget motor/trans into a 75 Spitfire? Spridgets 3
G Midget 1275 comp. Spridgets 16
G 72 Midget 1275 Spridgets 3
G 72 midget 1275 intake manifold Spridgets 1
lbc_newbie 1275 Midget, Sprite Timing Tape Kit Spridgets 2
NardisCNC 1275 for 66 Midget - Which one?? Spridgets 3
Steve P. 1275 in a later [1500] Midget? Spridgets 1
jbowlby Roller release bearing for 1275 Midget Spridgets 20
B 1275 exhaust on MKI Midget [1098] Spridgets 3
dingleberry3343 74 midget 1275 oil galley plug Spridgets 6
Thor Putting in 1275 motor into 1500 Midget Spridgets 4
S T-Series MG Midget 1275 Reverse Light Switch - Help Needed MG 1
S MG Midget 1275 Gearbox Oil - Help Needed MG 3
nathandarby67 WANTED: S.U. HS2 Dashpots [Midget 1275] MG 3
CARSINC WANTED: 1275 Engine Spridgets 0
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
