100M high oil pressure
61tr3
I know I crossed a line somewhere, I'm a Triumph guy helping a friend with a AH100M,
The initial problem was low compression in #3, we pulled the head and oil pan and removed the piston. Found the upper two rings lined up together and a groove was lightly scared into the cylinder wall. After a quick hone to remove the groove and a new set of rings for the cylinder; we reinstalled the piston and closed up the oil pan.
We added synthetic oil 20/50 and then started the engine. oil pressure blew out the spin on filter. The guage showed 100+ oil pressure. We took the regulator apart and cleaned, reassembled and the same results. We replaced the reg piston and spring, same results.
Any ideas of what were missing?
wheelguy
Been there- done that. You covered up the bleed back hole on the block with the oil pan gasket or sealer. It is at the oil presure relief valve. It lets pressurse bleed off from the back of the valve and goes back into the pan. With this blocked the relief valve wont move and you get over a 100lbs. of pressure. It is a tiny hole on the bottom of the block that is easy to cover up with gasket sealer. Take the pan off and see if you blocked it. wheelguy ( Allen Hendrix )
61tr3
Allen,
Thanks, you nailed it. we plugged it up with gasket sealer. We cleaned out the drain port, reinstalled the pan, added oil and started the car; 55PSI.
Thanks again and I just convinced two other people to join this group of british car lovers.
Glen
wheelguy
The great thing about this forum is you get to tap into the knowledge of others (like me) who have already done it 99 wrong ways first . Happy New Year!!
Wheelguy
Allen Hnedrix
WaltCasten
This thread (of course) came up just a day or two after I buttoned up the oil pan on my BN2. I used a non-hardening sealer, Permatex high-tack brush on and the gasket that came with the County brand conversion set.
Do you think I am going to have a problem? Not know this was a potential issue, I didn't really pay that close of attention to that area. May I ask what sort of gasket sealer you used?
Thanks,
Walt
wheelguy
Permatex is a non-hardning sealer. You may be alright as long as the gasket is not covering the hole. If you have a problem ... the Permatex will allow you to remove and replace the oil pan with no problems. Wheelguy Allen Hendrix
WaltCasten
Allen,
Thanks a lot for your help. Do you know if the gasket can go on the wrong way? I'm pretty sure it was symmetrical front to rear and I seem to remember it had a little cutout area on both sides about midway from front to rear.
Thanks,
Walt
wheelguy
There is a cut out for it. If you have not put oil in yet... drop the pan and see. If you have ..start the car and watch oil pressure. If it starts climbing toward 80lbs. "SHUT HER DOWN " and then drain oil and drop pan. If its is right you should not get more than 60lbs on gauge. Of course my gauge is off so 70lbs. on the gauge is really 60lbs. I would try it first. Just do not rev it til you are sure it is not going too high.
Allen Hendrix
Bob_Spidell New, and lively, 'discussion' on 'What is a 100M' Austin Healey 5
L The First "Factory" 100M Austin Healey 3
Editor_Reid For Sale 1956 Austin-Healey 100M [real one] Austin Healey Classifieds 0
bighealeysource Question on 100M front brake cylinder Austin Healey 4
lbcspinners Austin-Healey 100M auction on BaT! Austin Healey 36
HealeyRick 100M Brain Teaser Austin Healey 10
Healey Nut This one claims to be a real factory 100M Austin Healey 21
HealeyRick Earl's Court 100M on BaT Austin Healey 16
P 100M overdrive disengages on hot engine/transmission Austin Healey 9
Healey Nut 100m Austin Healey 9
P Healey 100M Cold Air Box Hose Fitting Austin Healey 20
Healey Nut Another 100M Austin Healey 9
W 100M that sold on Bring-a-Trailer aka BaT Austin Healey 13
S Anyone want a Honda 100M? Austin Healey 3
HealeyRick Earls Court 100M in Classic Motorsports Austin Healey 5
HealeyRick Earls Court 100M Austin Healey 9
Bob_Spidell Here we go again!: What is [and isn't] an Austin-Healey 100M? Austin Healey 3
R 100M For Sale RM Monterey Austin Healey 12
A 100M sold by Bonham's in Spa Francochamps Belgium yesterday Austin Healey 2
David Townsend Earls Court 100M Limited Edition Prints Austin Healey 0
bighealeysource Was 100M from Chasing Classic Cars sold this weekend? Austin Healey 20
David Townsend Gerry Coker Signature Now Available on 100M and 100S Collector's Edition Prints Austin Healey 3
H 100M on E-bay Austin Healey 37
David Townsend 100M Illustration Started Austin Healey 32
HealeyRick Another 100M Story Austin Healey 23
magman 100M etched carburettor numbers Austin Healey 4
bighealeysource Number of 100M's registered in 100M Registry Austin Healey 1
Editor_Reid The 100M & the Le Mans Kit & all that rot Austin Healey 37
HealeyRick 100M at The Quail Austin Healey 3
M Original Owner Factory 100M Austin Healey 31
A 100M or not ? Austin Healey 37
AUSMHLY For sale, 100m Austin Healey 31
MikeAH100M Treatment for Leather Bonnet Strap - 100M Austin Healey 9
J 100M Shift Boot Austin Healey 0
MikeAH100M Car Research - 56 100M Austin Healey 5
DerekJ Dealer 100M Austin Healey 16
R Earls Court 100M Sold Austin Healey 19
CLEAH What is a "Dealer 100M LeMans?" Austin Healey 32
MikeAH100M 100M Timing Austin Healey 3
HealeyRick Salad Days for the 100M Austin Healey 7
L 100M Carbs Austin Healey 1
MarshgrassA Another Dealer 100M question Austin Healey 13
bighealeysource Anyone know of a source for correct size "M" for 100M models ? Austin Healey 0
HealeyRick 100M at MM Austin Healey 14
H 100M "Dealer" on e-bay Austin Healey 3
Bob_Spidell Another "100M" ? Austin Healey 23
Editor_Reid 100M Introduction Austin Healey 9
V 100M detailed engine data Austin Healey 3
bighealeysource Craziness continues with 100M pricing Austin Healey 15
bighealeysource Best plug for BN2/100M Austin Healey 3
