1/4 spring parts source information
mightymidget
My new job driving a Greyhound Bus is puttin a hurt on my hobby. No extra time.
So I am reworking my 1/4 leaf springs and I am ready to put together. seems some of the parts I need are not available from moss and VB.
1.Center bolt: will probably use regular bolt if unable to source.
2.U bolt at axle end
3. and the sleeves that rest against the springs (u bolts)
What is ever body doing for the hardware when reworking. I don't have enough extra springs to rob the parts I need
Center bolt I used a socket cap bolt. U-bolt can from mcmaster.com I think. And the sleeve was just some metal tubing from the hardware store.
Just remembered, square u-bolts came from a boat/trailer place.
D Wedge Spring Cleaning / TR7 Parts Cheap Triumph 0
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 6
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
SpeedyG TR4/4A Door window regulator spring Triumph 5
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
2 For Sale Dr. Doolin Spring Compressor for TR3 Triumph Classifieds 0
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
P MGB 1974 MGB front spring length. MG 0
F 59 bugeye spring bushing bolt Spridgets 8
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Clutch slave "return spring"? Triumph 3
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
jfarris TR2/3/3A First drive of spring - I hate electricity!!! Triumph 7
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
B Poor quality BE replacement spring boxes Spridgets 0
B Any issue with cutting this weld on the spring base plates? Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
jfarris TR2/3/3A Relacing rear spring busings Triumph 3
J TR4/4A Seat install, Spring clip Triumph 0
F TR2/3/3A Leaf spring advice Triumph 16
K Missing spring clutch release lever Other British Classifieds 1
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
T Heater Door Spring Austin Healey 1
R General TR Spring collar flange thickness options Triumph 2
Editor_Reid Unusual Leaf Spring Austin Healey 4
J Tips for quarter elliiptic spring install Spridgets 3
L Welding Bugeye Spring Base Plate?? Spridgets 1
R TR2/3/3A Throttle rod spring location Triumph 3
pkmh Front Spring Removal For BJ8 Austin Healey 8
R TR2/3/3A Carb throttle return spring tension Triumph 2
Got_All_4 TR5/TR250 Spring question Triumph 1
P TR6 Spring checkup Triumph 1
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
66healey BJ8 shifter spring install Austin Healey 2
longbridgehealey Clutch return spring Austin Healey 7
A 1974 2500M Spring Rates TVR 6
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
GeorgeC Rear spring disassembly - BN1 Austin Healey 1
tr6nitjulius General TR Triumph Club of So Cal Spring Drive 4/27/19 Triumph 0
Joe Schlosser Quarter Eliptic spring bushing Spridgets 6
dougie SOVERN's Pacifc NW Vintage Racing Spring Sprints Season Opener Racing 5
M For Sale Churchill 18G106 Valve Spring Compressor for Austin Healey 3000 Austin Healey Classifieds 0
Lotus Club SoCal LCoSC - Spring San Gabriel Mountains Drive Lotus 0
S TR2/3/3A Front coil spring recommendation? Triumph 7
K TR2/3/3A Auxillary carb return spring in "More BS about TR,s" Triumph 9
