Spitfire ZS carb on 1980 Spitfire
wbdvt
Hi,
Ok now that winter is over in the Northeast, I am getting the car on the road. I bought this in Oct 2010 and have been getting to know it through the winter.
I have noticed an issue with carb. I did take it apart clean and new gaskets. It does have a funky manual choke that doesn't work and looks like a replacement/homemade job. The issue I have is that the piston gets stuck all the time. Prior to starting I remove the air filter and can not budge the piston with my finger. I have to take a screwdriver and pop it up to get it to move freely.
Is it possible to be out of round somehow? What to do?
BTW, the Home CFO has given approval to purchase a new carb if needed. I was contemplating a Weber DGV.
SkinnedKnuckles
The carb top cover may not be oriented correctly which could bind the air valve. There are a couple of alignment "bars" on the top & bottom part. I think the writing on the cover is oriented across the car as if to be read from the cockpit.
Also, the top cover needs to be tightened in a sequence and not just cranked down around.
W
wbdvt
Oh BTW I did tighten in a sequence. I did it small tighten adjustments at a time, moving in a star pattern.
SkinnedKnuckles
Well, a try, anyway. I don't see how the choke spring could be causing the problem, though, as the AV kinda floats on the mixing chamber pressure. You're not running real lean and having the air valve drive the needle into the jet on deceleration? Just guessing...
poolboy
Unscrew the damper piston (white knob) and remove it from the damper well, then see if the air valve still sticks.
Also from looking at the pictures, the carb and the manifold's mounting flange doesn't seem to be a match; not that it would make your air valve stick,..nevertheless..
W
wbdvt
poolboy,
thanks I will try that and report back. I thought that was a mis-match on the carb and manifold flange. I wonder if this had a different carb that was removed.
skiined - no, the problem is that after the car sits for awhile, like overnight, I can not move the air valve with my finger. I have to lever it free with a screwdriver, then it will move freely.
Could it be a carb that was put together from several and clearances are not in tolerance?
poolboy
The shaft with the damper piston may be tilted in the well, putting a bind on the air valve, But as soon as you remove the damper piston as I sugested, you'll know.
OR, might be a bit of corrosion that needs cleaning. About the only way to tell is disassembly and test fitting components until you uncover the culprit.
swift6
ZS carbs are much more forgiving of tolerances than SU's, especially when it comes to the air piston as it uses the rubber diaphragm and not a close tolerance fit between the airvalve and the bell. If the damper piston is ok, you might also check the height of the jet and or how far out (down) the needle is. The widest part of the needle near its base, could be sticking in the jet.
TonyPanchot
I did notice that you have partial blockage from the air cleaner back plate (after market) remove that bit of metal for the top vent and make sure that the side holes are open as well, looking at your second photo bucket pic.
Jon80spit
Mine does the same if it has been sitting a long while (3-6 months). Usually a squirt of WD40 and working it a bit and it comes free. It is caused by old gas gumming up the works. I also drop the bowl and clean the inside. Don't forget to clean the inlet float valve.
P MGB 1980 MGB carb and oil questions MG 3
F Wedge 1980 TR7 ZS Carb rebuild advice [need some] Triumph 5
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
E MGB SU carb air cleaners MG 10
Healey Nut Tri-Carb Project Austin Healey 213
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
tahoe healey Dumb carb question Austin Healey 23
jfarris TR2/3/3A Happy with my Paltech Carb rebuild Triumph 8
2 TR2/3/3A SU carb. Acts like an expansion valve ! Triumph 10
dbenichou289 TR2/3/3A SU carb linkages Triumph 2
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
O HD8 carb on Healey 3000 Austin Healey 62
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
R TR2/3/3A Carb throttle return spring tension Triumph 2
