T-Series Lazy Tach
PAUL161
Started the TF up yesterday to let everything warm up and circulate the oils and the tach started acting goofy. Holding the RPMs steady, the tach would rise slowly and sometimes would pass where it should stop and then slowly drop below the proper RPM point, slowly moving up and down, when I let the engine idle, the tach would sometimes drop to zero and adding a little RPMs it would slowly climb back up. The generator belt is not slipping, the tach reduction gear is working fine and the cable appears to be fine. It's not cold in the garage so any thoughts on this situation? :confused:
NutmegCT
Paul - I had similar issues on my '53 TD.
Turned out that the end of the cable entering the tach had dried grease on it. Dried great also on the internals of the tach.
I removed the tach, opened up and cleaned it, reinstalled. All has been well since.
Tom M.
PAUL161
PAUL161
Thanks Tom, did you lubricate the needles shaft? PJ
PAUL161
PAUL161
Problem solved! I put in a new tach drive cable when I restored the car, but I bought the cheaper cable with the blue cover on it and it went bad. The cheaper cable has a plastic sleeve on the end and it split and slid toward the end putting pressure on the tach drive, picture enclosed.Arrow shows where it is supposed to be. I replaced it with one that is as original with no plastic anywhere. A bit more expensive :rolleyes2: to say the least, but no chance of it fouling the tach drive where the cable hooks up. The original type cable is held in place with "C" clips on each end of the cable and can not move in or out of position. I did pull the tach apart and cleaned it internally and lubed it also. Works very well! PJ
B Lazy Tach Austin Healey 2
5 Lazy Tachometer Spridgets 14
glemon General TR Adjustable Trailing Arm Brackets, Cheap and Lazy, or clever like a fox? Triumph 0
milemarker60 Front Suspension Bolts/Nuts - Tub Dolly - LAZY!!! Triumph 2
MattP Cheap and Lazy windshield Restoration & Tools 2
B MGA Tach drive issue MG 1
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
Celtic 77 MGB Non working tach. MG 4
jackq Wanted Need a C Tach MG Classifieds 2
S Sticky Tach Spridgets 2
Joe Reed MGB Tach slow to wake up...why? MG 6
Lin Tach drive housing for BT7 Austin Healey 4
HealeyRick Tach Trouble Spridgets 2
W Tach wiring problems Jaguar 12
Marvin Gruber BJ7 tach cable location. Austin Healey 3
EWD TR6 ā€˜74 Tach Triumph 7
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
J 1965 BJ8 Tach Austin Healey 3
longbridgehealey Alternator conversion and tach Austin Healey 9
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A tach cable lubricant Triumph 4
D BT7 tach question Austin Healey 8
5 Tach Drive Generator for a Bugeye Spridgets 2
I Tach help Spridgets 3
Marvin Gruber BJ8 tach Austin Healey 9
Superwrench Tach not working Austin Healey 6
JimTR4 TR4/4A Capping off redundant tach cable connection Triumph 0
Zitch TR4/4A Tach and Speed inner gaskets Triumph 13
W Use of original Tach Spridgets 8
A Need help wiring my tach Spridgets 11
Patrick67BJ8 Tach Hookup Instructions from Nisonger Austin Healey 23
S TR5/TR250 tach problems Triumph 2
J Hunting tach and back fire TVR 8
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
M Tach generator gearbox Spridgets 6
M Strange Healey Tach Austin Healey 9
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
busybrit Tach stops when flashers are turned on !! Jaguar 3
busybrit Electrical tach issue on Aston Martin DB5 Other British Cars 2
AngliaGT What Goes to the Left of the Tach? Spridgets 3
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
J How can I tell if I have a negative ground tach? Austin Healey 5
E TR4/4A Speedo v Tach cable Triumph 2
rjc157 tach goes crazy Austin Healey 8
Sopwith_Camel tach-less Spridgets 11
J Tach drive housing eccentric Austin Healey 14
G MGB Tach and speedo rebuild. MG 3
