TR2/3/3A Standard Engine Trust Washer Thickness
mastaphixa
Bronze
The engine I am working on has had previous crankshaft work done as the main bearing shells are identified as being .010" under sized. The installed thrust washers have no markings on them. I have float of about .008". I can't tell if the thrust washer bearing area on the crank has been altered, so my question is, how thick are standard thrust washers? These washers measure between .090" and .094".
Thanks,
Steve Baker
LarryK
What car? There is a tolerance in the tables, I'll look it up.
M
mastaphixa
Bronze
Sorry, TR3. I know the tolerance is .004" to .006". Problem is I am at .008" so I have to do something about it. As stated above, I can't tell if the crank had the thrust washer area machined and oversized thrust washers installed or not.
LarryK
There are sized thrust washers. The shops usually don't mess with the side of the journals. +.001 on each side. Can plane outer side to make exact. Moss? Somebody has had to do a TR3 before, I haven't had to do them on a Triumph. Coming off a Holiday answers may be slow.
TR4nut
MOSS Europe has the stock thrush washers listed as 0.0925”. They have +0.005 available, one set might get you to the tolerance you are looking for, or possible just a fresh stock set will do it.
LarryK
You have to take the journal cap off to install the thrust washer. Remove it and check to see ifnthrust washer is installed with oil groove towards the rod journal. Then you can see what has been touched.
LarryK
The Roadster Factory has standard and .005.
Sarastro
Just one point--I'm looking at the spec in my TR4 shop manual, and it gives 0.004-0.006 "desirable." I'm not sure what that means, but it seems to say it's not a hard spec. Indeed, it gives a range of 0.0048-0.0117 in manufacturing, with a wear limit of 0.015. I find it amusing that they would spec such a wide range, but specify it to four decimal places. Strange.
LarryK
I find that all the British cars I have rebuilt or worked on have pretty precise measures. More precise than the domestic American cars of that era. Basically, because all the manufacturers in England built race cars after coming down from war when they built fighter planes, bombers, tanks and artillary. My machine shop that does my precision welding was leery of tackling a slider on a gear because "those Brits knew how to harden and measure steel".
TR3driver
Great Pumpkin - R.I.P
Your .008" is well within the new tolerance, and unlike the TR6 motor, these motors almost never have trouble with thrust washers.
Rather than go through the hassle of sanding down an insert, I would just put it back together at .008" unless you're going racing or something.
M
mastaphixa
Bronze
No racing here. So at what point would you be concerned with crank end float? I want to make a note in my manual.
CJD
I ordered the thickest washers and then used a glass plate, 220 wet or dry, and engine oil to sand them to the limit. If it has worried you for the last 11 days...why not do it right? It only took me 10 minutes to get the float spot on.
TR3driver
What I do is buy both standard and .005" sets, then use the combination that comes closest (but not under) the "desirable" .004 to .006" range.
If using +.005" on both sides did not get down to the .0117" spec, I would consider doing something extra (like having the crank cheek welded up and ground down). But it hasn't happened yet.
M
mastaphixa
Bronze
Randall,
Thanks. Where is the .0117" coming from? If it is experience, I certainly respect that, but am I overlooking something in the manual?
CJD
Still not sold...here's another sales pitch.
The engine is inclined in the chassis, so gravity will tend to move the crank rearward. The crank, therefore, spends most of it's time riding gently on the front thrust bearing. Now you go to engage the clutch. First the free space must be taken up between the clutch forks and throw-out bearing. Then the throw out bearing picks up the crankshaft and must drive it forward until "clunk"...all the thrust play is removed. Now the clutch can be disengaged.
If the thrust clearance is .006". you will never hear the "clunk" engaging the clutch, and the crank will never make an audible knocking from end play. If you approach 1/8" thrust play, then you are significantly affecting the clutch throw available...and you will notice the "clunk" regularly when the clutch is engaged. 1/8" at the clutch is more than all the clutch fork free play available in a well-clearance engine/clutch. Later you my be wondering why the clutch drags, even though all the settings are spot on.
So far we assume everything else is spot on. If you have a cocked rod or piston, the endplay knocking could be constant at idle and low speeds.
If I have to worry about an excessive clearance for more than 10 minutes during an engine build, then that is a sign I need to make it right! If you have been concerned for more than 10 days and you leave the clearance large, then you will always wonder...!?! It's a cheap, readily available bearing. Why give it another minute's thought?
TR3driver
Randall,
?? It's in both the TR3 and TR4 factory workshop manual.
M
mastaphixa
Bronze
Randall and John, thanks. I was focused on the .004 - .006 in the remarks column. the .0117" makes sense now. I do have a new set of standard washers that just showed up from BPNW so I will play with those and see if I can tighten it up to the preferred spec. They included a Yorks Peppermint Patty with my order! Do they always do that?
Steve Baker
dklawson
Steve Baker
Generally BPNW do throw a handful of candy into every order as a thank you. However, they do sometimes forget.
kindacreeky
On my engine for the Italia, I found 0.008" clearance with Std washers. Thus with the .005" oversize washers on one side, I measured .002-.003. I took the advise of CJD and ground the oversize down about .002. I now measure .004 clearance. As the center cap has some slight movement side to side (actually front to back), I had to fiddle with it a bit to get it even with the washer in the block. But the technique worked fine. I used 120 paper and then finished with 220.
HalLucy Standard Vanguard Sportsman engine and the TR3 Other British Cars 7
rlich8 Standard-Triumph Engine Package Diagram Triumph 4
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage MG Classifieds 1
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage Austin Healey Classifieds 0
S Wanted 1949 standard vanguard Other British Classifieds 0
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
S General Tech Standard for the Girling Bubble Flare Triumph 15
T Wanted Workshop manual for Triumph 10 [Standard 10] Triumph Classifieds 4
Mickey Richaud General TR Standard 10 Pickup! Triumph 3
T 1933 Standard Little Nine Carburetor Other British Cars 8
NutmegCT 1951 Standard Vanguard Other British Cars 3
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
Tim Tucker TR2/3/3A TR2-4 86mm standard rings Triumph 10
RickB standard size lug studs for 78 Midget? Spridgets 3
C Triumph Standard Flying 8 Triumph 5
M Thak you and Metric or standard.... ? Austin Healey 5
B TR4/4A Adding OD to Standard TR4 Gearbox Triumph 18
K Early 50's Standard Triumph 1/2 Ton? Triumph 8
wangdango Vandervell bearings for 100M, standard, main Austin Healey 3
bighealeysource Pertronix coil verus standard Lucas coil Austin Healey 3
QuickSilver Technical: Converting From Wire Wheel To Standard MG 6
kurts100 Bugeye Lever Shocks/Standard or Heavy Duty Rebuild Spridgets 14
hilsideser Standard 10 in S.C. on Craig's list for $300 Triumph 20
K TR2/3/3A Standard Continental Touring Kit for TR3 on EbayUK Triumph 0
TR4nut Standard Triumph Gray Colors for Russ.. Triumph 15
K 1950 Standard Vanguard Other British Cars 2
T Neat project - Triumph Standard 10 Triumph 11
Ohiobugeye Metric or US Standard Threads? Spridgets 26
Wirewheels Did the BJ7 come with OD standard? Austin Healey 11
germanmichel Standard clearance mainshaft of the transmission ? Austin Healey 3
W TR10 / Standard Axle for Lotus Triumph 10
pakiwi 1275 Cam Specs - Standard Spridgets 1
PeterK standard-triumph hardware catalog Triumph 7
MadRiver TR6 Standard TR6 Tires? Triumph 2
ncbugeye Tyres for standard Bugeye rims Spridgets 1
G Standard Vanguard Paint Code Other British Cars 4
Alan_Myers If I had room, time, $! FS: '47 Standard Flying 14 Triumph 2
Sherlock Standard Herald [India] Other British Cars 5
A MGB How much Torque can a standard MGB gearbox handle? MG 5
bobh A Radical Idea? Or An Old Standard? Triumph 11
gsalt57tr3 1953 Standard Vanguard Phase II Other British Cars 0
gsalt57tr3 Standard Vanguard Triumph 2
gsalt57tr3 Standard Vangard in St. Louis MO Triumph 2
Webb Sledge David Vizard: Tuning Standard Triumphs Triumph 2
Sherlock History question - Standard-Triumph of Belgium Triumph 3
R air shocks vs.standard type? Triumph 3
Webb Sledge Tuning Standard Triumphs Triumph 0
4 1947 Standard Flying 14 Info Other British Cars 5
UltimateQuestion Standard-Triumph T-10 Triumph 10
S Standard Triumph publications list source wanted Triumph 0
