MGB Contemplating a conversion
Platinum
The charging system in our B is giving me fits. Put a new set of brushes in the generator a month ago, the voltage output was fine for a month. Last Wednesday the voltage dropped to battery voltage and no higher. Out with the genny, brushes looked fine, polished the commutator and reinstalled... no joy. Have a NOS regulator on the shelf, swapped out the older one, and again, no joy. Matter of fact the iggy light never went out so I assume the NOS regulator sat too long in the box and the points on the right side coil are stuck closed. Dressed the points in the original regulator, put it back in and still no charge. grrrr...
To eliminate the whole durn'd problem I'm thinking of going with an alternator conversion and a "dummy" regulator. Car is already changed to negative ground, did that with the rebuild a decade ago.
Anyone done this swap on a pre-'68 B? Really a straightforward conversion but not cheap. It'll put a real dent in me CAB budget.
Platinum
Platinum
Just a voltmeter. Made up this console for it and a clock:
Platinum
Thanks, guys. Saw something similar someplace on th' innerwebs, years ago. Finally got a burr under me saddle and put this one together. Still need to do a bit of "fine tuning" to make it acceptable to me. Likely a "charging port" (a.k.a cigar lighter) in there someplace.
Platinum
The deed is all but done. Took a couple hours at a leisurely pace. Got the rear bracket from Moss from their "conversion kit", sourced the alternator locally, the 'fake regulator' is due to be delivered later today. Did a bit of fettling with the coil mount instead of drilling more holes in the inner wing. Measured and relief cut the original bracket on the motor mount. Rerouted the wiring with a pair of male-to-male spade connectors for the indicator light/field lead, had to fab up a three-blade spade connector from some scrap bits of aluminum sheet for the three power leads. Now a reliable 14V steady electron flow. When the fake box arrives it'll take about ten minutes to put it in place. Could probably have 'converted' the real regulator but didn't want to cobble it.
The coil bracket is difficult to see, but it was cut on the band saw, parallel and even with the top of the motor mount for about three inches and angle-cut at just under a forty-five degree angle toward the coil end:
The 'bodge' with the wiring until the fake regulator gets here:
Platinum
Heheee... postman arrived, I opened the package and swapped out the cover on the "fake" with the cover of the original. Ignition on, started the engine, no smoke, all good! The dummy is fitted inside with a 50A fuse. Very clever do! And it took UNDER ten minutes. :wink:
Mickey Richaud
Nice job, Bubba! :thumbsup:
Platinum
D said:
Hoping you never need 50amps........;)
As the new alternator is rated at 45 Amps, my mind is unconcerned. :smirk:
Thanks. I try. :wink:
PAUL161
What a nice job Doc! I've been contemplating installing an alternator conversion for the TF, using one that looks like the generator, they also have a fake regulator that looks like the original, with the driving lights on and the heater, it has all it can do for the generator to keep up.
This one,
Gliderman8
Nice work doc!
drooartz
Nice work, Doc.
Platinum
Thanks, fellas. Appreciate the comments.
I think if I'd seen Paul's T-series alternator disguised as a generator sometime earlier I may have bit th' bullet and paid the price for one of those. There are some clever lads producing these things, wish I'd thought of doing it! Must be a market for the stuff, has to be an investment in producing them.
The purist in me kinda balks at seeing an alternator under-bonnet of the B here, but as a practical matter I've already changed many of the "correct" components and an MGB is hardly a rare collector car. This one was intended to be a driver. I've tried to build in reliability over originality. If anyone is of like mind, I would heartily endorse an aluminum radiator swap, as well. In summer here it now will idle in traffic and not give me angst as I watch the temp gauge. I also fitted an electric fan with a thermal switch to kick it on at 185°F and an override switch on that console pictured above.
Thinking I'll run it "outside th' yard" sometime next week, make a 100 mile round trip to Sarasota to help my pal down there sort some electrics on a P-5 Rolls.
drooartz
I'm a big fan of this approach -- functional changes are welcome. Many of the changes happened in later cars (like mine, factory with alternator) anyways.
I did the aluminum radiator a few years ago, a nice upgrade for sure. May consider an electric fan at some point as well, given the heat and altitude I deal with.
Platinum
With the one here, in traffic it gets turned on to run continuously and the temp stays at thermostat temp. Big improvement over the original setup.
JPSmit Loosely contemplating an engine swap for Ms Triss Spridgets 14
K Contemplating restoration of '76 XJ6C Jaguar 8
TR4nut TR2/3/3A Contemplating TR3A suspension change Triumph 6
jhorton3 Contemplating...No Stop That! Spridgets 11
AndreL TR6 Conversion to electric fuel pump Triumph 10
mctriumph TR2/3/3A Ultimate fan conversion Triumph 10
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
zoohow TR6 Carburetor Conversion kit Triumph 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
R Smitty Toyota Conversion Angle Drive Austin Healey 16
P Positive to Negative Conversion Austin Healey 1
P Pos to Neg Conversion Austin Healey 1
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
D transmission conversion Other British Cars 1
W TR2/3/3A Wire Wheel Conversion Triumph 5
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
petnatcar Breather Hose Conversion Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye disk brake conversion Spridgets 10
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
C TR2/3/3A Rack and Pinion Conversion for Tr's Triumph 0
Walter74 Throttle Cable Conversion Austin Healey 6
PAUL161 T-Series Dynamator Alternator conversion. MG 23
M Dynamo to "Dynamator" Conversion Austin Healey 2
S Stag Lucas 18ACR alternator conversion Triumph 5
H Shock absorber conversion Austin Healey 3
S MGB MGB engine conversion MG 27
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
J TR6 Moss HS6 SU conversion kit question Triumph 4
roscoe 5 speed conversion question Austin Healey 9
maxwedge5281 bought back my first nasty boy conversion!! Austin Healey 6
I Bug eye front disc brake conversion. Spridgets 5
steveg Cost of V8 conversion Austin Healey 34
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
M TR6 5 speed conversion Triumph 33
C AUF214 solid state conversion question British Motor Corp 0
I TR6 TR6 EFI Conversion Triumph 19
69MGC MGB B V6 Conversion Recommendations MG 4
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
