Loosely contemplating an engine swap for Ms Triss
Bayless
Might be a bit tight but workable.
anarchy99
If I had the money I would hands down buy that purely just to find something to put it in!!! Aside from a P-51, etc... The Tri-5 Chevy comes to mind
JPSmit
JPSmit
If I had the money I would hands down by that purely just to find something to put it in!!! Aside from a p51 that is
You and me both. I would clean that up and keep it in the house
SaxMan
Then of course, there was this car:
https://www.autominded.com/3741_the-beast-27-liters-of-rolls-royce-power/classic-cars
It originally had a Rolls Royce style grille, but RR complained, so he ended up with the "Family Truckster" look.
The Meteor is a "detuned" Merlin -- same displacement, but putting out "only" 600 horsepower...on low octane gas. Used in the Cromwell, Crusader and Centurion tanks. I'd bet with some tweaking you could get it back into Merlin horsepower range. Might be a little bit much for a Sprite
aeronca65t
As Old Yeller builder Max Balchowsky's sign used to say, "We can replace anything with anything."
Yep.....so true!
JPSmit
JPSmit
DrEntropy MGB Contemplating a conversion MG 25
K Contemplating restoration of '76 XJ6C Jaguar 8
TR4nut TR2/3/3A Contemplating TR3A suspension change Triumph 6
jhorton3 Contemplating...No Stop That! Spridgets 11
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
