TR2/3/3A Sway bar attachment points
Jim_Stevens
I’m looking at not attaching my ADDCO sway bar to the bumper irons... rather, Welding a short 2x2” mild steel tube to the end of each frame and connecting to that. I would also forgo that short extension to the lower wishbone arm and attach the sway bar directly to the middle spring pan bolt.
The only issue I have is whether it’ll have sufficient freedom of travel as the suspension moves through its whole range. Unless one of you thinks of another. Especially interested in Tush’s opinion, since he has one mounted to his bumper irons. (You think nobody watches your videos?!)
karls59tr
Bronze
Jim On page 21 of Bob Shallers "More BS about TR's" there is a description and pictures of a better way to mount the sway bar. I did this years ago and it works great. Maybe someone who sees this could post the pictures for you?
Karl
SASSAMON
Jim,
If you do not have a copy of Bob Shaller's book here is the pertinent information on the Anti-Sway Bar.
Jim_Stevens
Jim_Stevens
Karl
For sure— that’s the backup plan. I just saw that the sway bar was almost exactly 2” from the end of the frame when the attachment piece is not used, so thought I’d try that. May not work. Jim
jfarris For Sale TR3 Rear Sway Bar Triumph Classifieds 0
B TR6 Sway bar Triumph 3
Hamish Racing TR2/3/3A Sway bar rose joints and diy brackets Triumph 4
S Sway Bar End Links Austin Healey 15
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
steveg TR6 Fixing Twisted Sway Bar Bracket Triumph 2
tahoe healey Sway Bar Bushings Austin Healey 3
C Front sway bar mounting? Austin Healey 10
R TR2/3/3A Front sway bar Triumph 12
H broken sway bar link - again Austin Healey 8
jfarris TR2/3/3A Front Sway Bar on a 56 TR3 Triumph 13
M TR4/4A Front sway bar measurements required. Triumph 0
PatGalvin TR2/3/3A Rear Sway Bar experience Triumph 5
H TR2/3/3A Sway bar fitting Triumph 7
davidb front sway bar BT7 Austin Healey 4
L Sway Bar / Anti Roll bar bush replacement 100/6 Austin Healey 7
B Anti-sway bar for a earlier BJ7 Austin Healey 3
A TR5/TR250 Front Sway Bar Installation Problem Triumph 3
T TR5/TR250 250 Sway Bar Link Triumph 0
1 Sway bar installation Spridgets 9
M XK140 Sway Bar Bushings Slipping out of Brackets Jaguar 1
G TR2/3/3A Front Sway Bar Installation on Wide Mouth 61 TR3 Installation Problem? Triumph 9
sim sway bar for a 58 Spridgets 3
S MGB Rear Sway Bar MG 2
J Sway bar interference Austin Healey 10
doughairfield TR4/4A TR4 Front sway bar install question Triumph 9
Boggsy64 MGB Need help sway bar end bushings MG 12
C Sway bar upper installation help please Austin Healey 3
blueosprey90 MGA An Alternate Sway Bar Link for the MGA with MGB Sway Bar [ a repost] MG 1
H broken sway bar link Austin Healey 13
H WTB urethane sway bar centre bushing Austin Healey 5
T BN1 Front Sway Bar Austin Healey 0
T TR2/3/3A TR2 Sway bar questions/info request Triumph 5
O BT7 sway bar advice Austin Healey 3
T 100 4 Front Sway Bar Austin Healey 12
pkmh Sheared Bolt - Sway Bar Bush Strap to Chassis Austin Healey 29
R TR4/4A Tr4a new anti sway bar, maybe almost perfect! Triumph 5
R TR4/4A Tr4a, any tips about this sway bar Triumph 2
Jim_Gruber Rear Sway Bar - Needed? Spridgets 10
R TR4/4A TR4A sway bar , any vendor differences Triumph 11
G Sway bar mounting area trouble? Spridgets 14
W sway bar link bushings fit problem Austin Healey 3
Willie_P TR2/3/3A TR3/4: sway bar options [GM, Ford, Chrysler, etc] Triumph 3
Geo Hahn TR6 TR6 Sway Bar Bushings Triumph 1
G Spring, suspension and sway bar options Spridgets 15
D sway bar bushings Austin Healey 3
M TR4/4A TR4 rear sway bar installation Triumph 15
W Spitfire Rear Suspension Sway Bar?? on 1980 Spitfire Triumph 5
T TR4/4A Just finished retrofitting the TR4a w/sway bar Triumph 4
T TR4/4A Correct front radiator tray for TR4a sway bar? Triumph 6
