MGB 1974 MGB- New main wiring harness, but no start
wkilleffer
Good evening,
I finally got my dash back in place, harness hooked up, new battery, and was really looking forward to starting the car tonight.
Sadly, no joy...
The headlamps, tail lamps, turn signals, and hazard flashers all work. When I turn the key, the ignition light turns on and the fuel pump does its thing. But no cranking.
I've also noticed no courtesy lamp illumination.
I swapped the harnesses by leaving a portion of the end of each wire in place so I could color match and plug in the appropriate wire. To the best of my knowledge, I did this correctly.
Down at the starter, I'm getting 12+ volts, which isn't surprising considering that the lights work. Also not surprising that the appropriate terminals on the fuse box also get 12+ volts.
Seems like 1974 was a year where the driver's seat belt was required to be fastened before the car would start. Mine would start without it being fastened. Is it possible that in replacing the whole main harness that I inadvertently re-activated that feature?
Where are some other places to check for voltage?
Any assistance would be appreciated.
Thank you,
-William
JPSmit
Is your engine grounded? That would be my first place too look. I also once had a similar issue where it was as simple as two reversed wres on the solenoid
Mickey Richaud
How do I check if the engine's grounded?
There should be a braided or battery cable attached to the engine mount or somewhere along the bell housing or engine block, and then attached to the body. Something like this:
bob67bgt
William,
On a 74 there should be a starter relay on the firewall. Brown wire comes from the fusebox. Check for hot all the time on the brown at the relay. The seat belt interlock is behind the radio console and has a big white plug with lots of wires. If the interlock unit goes bad it will not let "start" power go to the relay. I have had to disconnect and jump the wires here to make 2 of my rubber bumper 74 GTs starters work all the time. They were hit and miss when starting. I can give more details after I get back from a breakfast appointment if needed.
wkilleffer
wkilleffer
The brown wire has 12 volts at the starter relay.
I remember seeing the seatbelt interlock when I was doing the harness replacement. What I don't remember is whether or not there were any jumped wires or other obvious modifications. I still have the remnants of the original harness and can have a look at it.
I wanted to test the relay itself, but wasn't sure how without an assistant in the driver's seat. Live by myself, so someone's not always available.
Thank you,
-William
William,
drooartz
So do we have a vroom vroom moment?
wkilleffer
wkilleffer
We have vroom-vroom... There are still a few things I need to finish, but I couldn't resist a quick spin around the block.
drooartz
Woohoo! :cheers:
So hard to resist that drive once it's running, even if all else is still not well. If nothing else it's a great motivator to keep going through those last projects.
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
VeeCee MGB 1974 MGB Roof Installation MG 0
P MGB 1974 MGB front spring length. MG 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
A MGB MGB 1974 windscreen centre rod replacement MG 5
HAN5L778 MGB 1974 1/2 MGB Project car MG 0
J MGB 1974 1/2 MGB gasoline type MG 5
wkilleffer MGB 1974 MGB convertible top anchor bar size MG 4
wkilleffer T-Series Clutch pipe installation- 1974 MGB MG 2
N MGB 1974 MGB Questions MG 5
K T-Series Trailer Hitch for 1974 MGB Roadster MG 4
Monark192 MGB 1974.5 MGB vs. 1975 model. Which to keep? MG 19
wkilleffer MGB 1974 MGB distributor drive dog- which one is it? MG 8
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
wkilleffer MGB MGB 4-way fuse box question- 1974 MGB MG 8
C MGB-GT 1974 1/2 MGB GT MG 37
1 MGB 1974 MGB in Florida MG 15
M T-Series 1974 mgb ignition switch/lock w/harness MG 10
7 MGB My Project Car 1974 MGB Convertible MG 50
C MGB 1974 MGB ready for lots of work and help with questions:] MG 6
P TR6 Horn issue 1974 TR6 Triumph 5
D Trying to get back working on the 1974 Midget Spridgets 11
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
A For Sale 1974 TR6 Triumph Classifieds 1
Marvin Gruber For Sale 1974 TR6 for sale, $7200 Triumph Classifieds 3
D For Sale 1974 triumph spitty davidschab60@gmail.com Triumph Classifieds 0
J 1974 Jensen Other British Cars 22
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
C For Sale 1974 TR-6 Project car for sale whole Triumph Classifieds 0
H TR6 1974 tr6 allison xr700 Triumph 12
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
R SOLD!! 1974 Jensen Healey Other British Classifieds 0
bravenrace For Sale 1974 TRV 2500M FOR SALE Other British Classifieds 2
krswen For Sale 1974 Panther J72 Other British Classifieds 4
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
S For Sale MG Midget Workshop Manual on CD/ROM - 1962 - 1974 Models MG Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Spridgets Classified 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Austin Healey Classifieds 0
A 1974 2500M Spring Rates TVR 6
L TR6 1974 Tr6 ignition switch Triumph 3
T TR6 ajustable training arm brackets--- 1974 TR6 Triumph 14
C I'm looking at a 1974 MG Midget [chrome bumpers with black sabrinas] Spridgets 9
B 1974 Midget Spridgets 6
jmayzer For Sale 1974 MG Midget Mk III [Maryland, USA] Spridgets Classified 1
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
M 1974 Jensen INterceptor electrical help needed Other British Cars 8
F MGB Correct steering wheel - 1974 MG 2
