G
I've mounted a 16" electric fan to my radiator (puller) and plan on installing my heat sensor into the middle of the top radiator hose (from my water pump to the radiator) using one of those alloy Tee's that everyone removes from later model TR6's. I found a new one. What temperature should I select as ideal for the sensor probe to activate at to automatically turn the fan on. There are a number of probes available that screw into this Tee and allow the probe to sit right in the middle of the coolant flow to accurately sense the temp at it's hottest point. Too, I have an ideal location to get my 12 volts from, straight off the back of my Delco alternator that is fed to the battery with a really heavy gauge wire (8 gauge). Trying to reduce the extra lengths of wire to the battery or even the starter. If I can keep all my wiring on the left side of the engine bay, I can place my relay and access my fuse block a lot more neatly. Will use a DPDT switch to override the sensor as needed, all lighted on the dash to monitor fan activity. Will of course hard wire in the appropriate inline fuse where appropriate. Following Dan M.'s diagram.
Bill
Bill
