I have a 62 MkII BN7 Tricarb. It was restored in the US a few years back. The engine had some trouble when I got the car (it was shipped to Germany, where I had moved in the meantime) so it had to be overhauled - the block had a crack.
The car now has a completely rebuilt engine: New block, new crank shaft, new forged pistons, Denis Welch DWR8 cam, alloy head with polished ports, larger valves (regular lift rockers), new manifold, sport exhaust, oil cooler. The ignition is standard. Then carbs are three SU HD6 with regular air filters.
Here are my questions:
1.) The shop where the car is at in Germany has no real recommendations on the needle and piston spring setup for this configuration of engine. The car runs so so at this point - plugs fouling up on low rpm and engine overheating on high rpm and power poor. I found a recommendation for a setup on the web at a British Healey club: SQ needles and 8OZ spring. Any thoughts on this?
2.) Everyone I talk to tells me to go to Webers on this type of setup. They say it will give me 30 to 40 bhp more instantly and will be much easier to tune. Make sense?
