Air Filters for Triple Webers, BT7
Bugeye58
A friend is having trouble with filters on his BT7. He's running triple SK's, which are a virtual DCOE clone, and the K&N # 56-1310's are too deep to mount. They're 1.750", and he's looking for something thinner, preferably 1 1/2" or less. Do any of you have a recommendation I can pass along to him?
Thanks,
Jeff
When I first installed the 45 DCOEs on my car, I had to modify the rearmost airfilter to fit between the carb and pedalbox. I was using filters that held a piece of filter/foam between an inner and outer boundary (3 separate pieces) of expanded metal screen, thus, it was easily modified to be shallower.
When the whole car was dismantled, I modified the pedalbox so that I could fit "store-bought" airfilter elements (approximately 1-3/4" x 3 x 5). The three (3) elements are concealed inside one (1) airbox.
First picture shows removeable s/s cover before the holes were cut & belled.
healeynut
What the heck is that big monster tube you have running from the truss to the kickpanel/door hinge pillar? Is that for T-bone crash safety? If so, how is it fixed on the other side of the kick panel?
GregW
Platinum
Hi Jeff,
I had a heck of a time finding a filter to fit my Mikuni carbs. The problem was (is) the assembly process of the K&Ns. The rubber ends cover a lot of the filter element itself. So a 1 ½” high filter has about a ½” of filterable height, same goes for those green filters. I wound up making my own filters using Uni foam and some spare aluminum I had lying around, .090 I think. Here’s a picture to get the creative juices flowing. The end caps were aluminum brazed together.
BlueRidge2
Just a guess but I would think to take the flex or twist out of the chassis whilst charging hard in and out of sharp corners. Br2
GregJ
one thing to be careful of is the distance between the air intake trumpet and the cold airbox wall. In order to draw sufficient air for optimum horsepower the distance from the end of the airhorn (or what ever opening you have) should be 2 times the diameter of the air opening itself. I would be concerned by the air management in the set-up of Randy Forbes car as pictured in the previous post.
GregJ
GregJ
I also would have a hard time being comfortable with the position of the brake reservoir so close to the exhaust manifold, especailly with no heat shielding.
GregJ
GregJ said:
... I would be concerned by the air management in the set-up of Randy Forbes car as pictured in the previous post.
GregJ
And:
GregJ
Fortunately for you, you don't have to be comfortable with my car.
FYI: The airfilter elements are the same ones as supplied by any of the popular Weber suppliers, they're just in a different box (same height parameter). I wanted the three (3) carbs to be tied together so the linkage acted uniformly; with soft mounts, it's easy to have one carb flex up and another down. Hence the common airbox.
Sure, I would've liked to have enough room for a full works style induction setup, but in 1986, these manifolds were all that was available for a LHD car. Besides that, I wasn't up for modifying the shroud for access. Back then, the all-up price was about $600.00 (SC Austin-Healey UK). Kinda hard to touch them for that price today.
I've never had a problem with my brake fluid catching on fire either; the headers and reservoir have been that close since 1978, when I bought it.
The main hoop diagonal bar has been reconfigured since this original "out of body" shot was taken, but you get the idea of the network. Not shown are the connectors inside the front rectangle tubes; all four (4) corners of this chassis are firmly tied together. The entire cage fastens to the chassis at fifteen (15) points.
Revised main hoop diagonal:
GregJ
Randy,
Your doing fine...I did not intend to imply your set-up is "wack." I just commenterd in case others were interested ( like the original poster) regarding constructing air intake boxes for the carbutetors. My 100 has weber carbs (45mmDCO3's) and I had the same problem of space with air intake. Really the best solution is foam filter "socks" as they will bend around any obstrucion without creating a solid baririer. To each his own...
Regarding the brake fluid reservoir...same comment. For sure I would not expect your brake fluid to catch fire???? However frequent heavy brake use, like under racing conditions, would soon heat-up the fluid. That situation together with the proxiominty to the radiant heat from the exhaust manifold, you would soon realise reduced braking efficiency. Again my observation for anyone contemplating a similar set-up when deciding how to deal with the filter problem.
Just my $0.02...probably worth less than that.
GregJ
G triple zs air filters - any ideas? Triumph 4
S TR2/3/3A restore my original air filters Triumph 5
N Air filters Austin Healey 5
JFS TR2/3/3A Weber Air Filters Triumph 7
doc50 Wanted H2 Air filters for 73 Midget Spridgets Classified 0
PeterK TR4/4A DCOE air filters Triumph 5
B Welch air filters Austin Healey 5
F What to do with breather pipe as my new air filters have no connection for one? Austin Healey 31
T General Tech NOS Paper Air Filters, Shelf Life Triumph 2
T TR2/3/3A Finally found and fitted paper carb air filters on my TR3 Triumph 28
T TR2/3/3A Question on paper air filters for TR3 Triumph 3
M TR4/4A What modified carby air filters to use on my TR4 RHD. Triumph 19
T TR2/3/3A How can I bend TR4 air filters to keep them from hitting fender on TR3A? Triumph 1
PatGalvin TR2/3/3A TR3A After Market Air Filters? Triumph 31
Gearhead_Garage Big Healey Air Filters Austin Healey 22
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
Lin K&N Air Filters for SU HD6 carbs Austin Healey 14
D TR6 Air filters Triumph 2
S Best air cleaners/ filters for street Spridgets 8
G K&N air filters for 1967 BJ8 Austin Healey 6
fad64b TR2/3/3A TR3 Air Filters Triumph 7
A Anyone have air filters to sell? Triumph 5
A TR2/3/3A What air filters for '59 TR3? Triumph 17
H filters inside of BJ air cleaner? Austin Healey 24
I Stock bugeye air filters Spridgets 9
K SU Carb Mix...Air filters on? Triumph 4
E Painting stock air filters Austin Healey 7
8 TR4/4A Upgrade Air Filters for Stromberg TR4A Triumph 6
M TR2/3/3A Proper servicing of TR3 air filters Triumph 20
G Where can I find the chrome "MG" air filters? Spridgets 4
S Wedge TR8 non EFI, Air Filters Triumph 2
D K&N Air Filters MG 5
D Ported/Manifold vacuum and air filters MG 0
A Unusual Air Filters Triumph 28
johnrip Wedge TR7 with K&N Air filters. Where to mount dipstick? Triumph 2
JohnnyMead TR2/3/3A Re-Oiling the TR3 Air Filters Triumph 0
J Removing air filters on AH Austin Healey 8
KVH SU Carbs Paper Air Filters Triumph 4
humanoid replacement air filters for dual Webber carbs Triumph 19
K Best air filters? MG 7
ArtQ Air filters Austin Healey 2
jjbunn New Air Filters for Harold MG 10
jjbunn Air Filters MG 32
Team_Sprite finish on 948 air-filters Spridgets 12
S TR2/3/3A tr3 air filters Triumph 3
sparkydave Anybody use Longflo air filters? Spridgets 15
Woodie stock 70 air filters Spridgets 22
mperdue source for air filters MG 8
P Cleaning carburator air filters Austin Healey 2
Z Air Filters Austin Healey 14
