middleagecrazy
Help
Dad left the Spitfire with me to try and straighten out the wiring. Here is the issue. Number one is that the gas gauge moves with the blinkers. It is a new gauge and sending unit. I can't find anything in the manuals about the voltage stabilizer that is in the circuit that is on the back of the tach. I check Moss Motors and they list the Voltage stabilizer as NA. I understand that NA means "NO LONGER AVAILABLE" This is the same issue we had before replacing the sending unit and the gauge. Doe's anyone know the function of the stabilizer? I Ohm'ed it out and it only has .003 ohm of resistance across the terminals however it has .008 ohm from the terminals to ground/earth. It seems logical that the purpose of the stabilizer would be to filter line noise from the circuit. Anyone have a suggestion as to a solution.
Thanks in advance
Anthony
Thanks in advance
Anthony
