Voltage stabilizer
middleagecrazy
Help
Dad left the Spitfire with me to try and straighten out the wiring. Here is the issue. Number one is that the gas gauge moves with the blinkers. It is a new gauge and sending unit. I can't find anything in the manuals about the voltage stabilizer that is in the circuit that is on the back of the tach. I check Moss Motors and they list the Voltage stabilizer as NA. I understand that NA means "NO LONGER AVAILABLE" This is the same issue we had before replacing the sending unit and the gauge. Doe's anyone know the function of the stabilizer? I Ohm'ed it out and it only has .003 ohm of resistance across the terminals however it has .008 ohm from the terminals to ground/earth. It seems logical that the purpose of the stabilizer would be to filter line noise from the circuit. Anyone have a suggestion as to a solution.
Thanks in advance
Anthony
Dave Russell
Yoda - R.I.P
The so called voltage stabilizer is litte more than a specialized blinker. It's contacts open & close to maintain an AVERAGE voltage of 10 volts or so as measured over a period of time. If you just put a meter on it, it would go from 12 volts to zero periodically but the average would be 10 volts. Since the gages are thermal, it takes time for them to respond to the changes of supply voltage & they don't respond to the relatively rapid blinker/regulator switching changes.
I don't think anything but the gages should be connected to this circuit. It appears that the turn signal feed may somehow be connected to this circuit, instead of to a solid 12 volt supply.
Adrio
I ran a bench test on a gauge to and sender unit to determine what voltage would be "equivalent" to the old thermal voltage stabilizer. What I cam up with is a 12V solid state regulator with the ability to deliver enough courrent for all your gauges works great. That is what I used for mine in place of the thermal unit and it has been working perfect for over 10 years. I built mine but I think I saw some for sale online some place.
70herald
HI Anthony
As was pointed out, the "stabilizer" really just turns the power on and of at a high frequency. The equivalent "steady" voltage to get the gauges to read correctly is about 10 volts.
The easiest way to get this is to use a 7810 voltage regulator. It only has three leads. Input, ground and output. It has more than enough capacity for all the gauges on a spit. The data sheet says you need a capacitor and other stuff, but for this application it is overkill all you need is the regulator. Note that the heat sink is connected to ground so be careful where you place it. I just soldered mine into the can from the old regulator and hooked it up with the original contections. This is what I have in my Herald.
By the way, the standard regulator is available but is harder to find and will cost way more. The 7810 is probably available at Radio Shack or other elecltronics supply shop. you can probably get it for about $1.
Yisrael
danmas
Keep in mind that the solid state regulators won't have the temperature compensation that the original does, so your gauges will be off a bit as the temperature changes.
dklawson
Dan, you've made the temperature compensation argument before... but I'm curious how much error this will make on Smiths instruments. I've seen Smiths stabilizers with outputs ranging from 9 to 11 volts. Would you expect more than such a 10% error from temperature compensation?
As for the 7810, that chip isn't available from Radio Shack but it is available from sources like Mouser, DigiKey, and Newark Electronics (all of whom will sell through the web).
Download my PDF from:
https://home.mindspring.com/~purlawson/files/SmithsVoltageStabilizer.pdf
It should help you troubleshoot the gauges and help you either calibrate or replace your stabilizer.
Dave Russell
Yoda - R.I.P
I think you're missing the original question.
"Here is the issue. Number one is that the gas gauge moves with the blinkers."
Not which IVR is the best. The "blinkers" were never meant to be run off of the IVR & should have no effect on the gages.
dklawson
Sorry Dave. Good point.
As Dave said, make sure that you have hooked the blinker/flasher relay up correctly. It shouldn't have a direct connection to the voltage stabilizer... certainly not to the 10v side of it. BTW, the 12v side of the stabilizer has spade lugs marked with a "B" for battery while the gauge terminals on the stabilizer are marked with "I" for instruments.
middleagecrazy
middleagecrazy
Thanks for the response. I have disassembled the stabilizer and found that there was corrosion inside at the point of Ground/Earth. I have cleaned the unit and plan to install it for a test this evening. While I had it out I did the ohms test to verify that the unit was not broken. There was also corrosion found on the inner points. This was cleaned up also. I should be able to respond with the test results tonight.
Thanks Anthony
dklawson
The points inside the stabilizer are factory preset to give a time averaged 10v on the "I" terminal. Once you sand or dress them to remove corrosion/pitting you will probably need to recalibrate the stabilizer. That procedure and the necessary equipment is discussed in my PDF (link above).
middleagecrazy
middleagecrazy
Well after reading the information supplied by everyone. I find that sense the Gauge is an aftermarket unit the Voltage Stabilizer was not needed. However it was necessary to correct the voltage to obtain the proper read out of the gauge. I found that in my particular instance this could be accomplished by installing a 100 Ohm resister in the power wire that feeds the gauge. Now when I have a quarter of a tank the gauge reads one quarter. I thank everyone that fed me the information needed to diagnose and resolve my dilemma.
Thanks
Anthony
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
T TR4/4A Why is the new voltage stabilizer I got marked with 'top"? Triumph 4
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
S TR4/4A voltage stabilizer Triumph 2
S TR4/4A Voltage stabilizer and cable routings? Triumph 5
Mink TR4/4A Moss voltage stabilizer, part number 131-555 Triumph 15
M TR4/4A Voltage Stabilizer question. Triumph 10
M TR4/4A Voltage Stabilizer TR4A. Triumph 14
Bob Claffie Voltage stabilizer Triumph 10
B Gas Guage Not Working--Voltage Stabilizer? Spridgets 17
RJS Voltage Stabilizer [Mal]Function Triumph 3
T Voltage stabilizer, turn signal flasher, hazard Spridgets 2
Brosky Leaky voltage stabilizer Triumph 7
Raymond voltage stabilizer MG 15
L Voltage Stabilizer MG 20
Got_All_4 Voltage stabilizer alternator upgrade problem Triumph 2
M Normal Temp and Voltage Stabilizer MG 9
Trevor Jessie Voltage stabilizer Spridgets 4
Mickey Richaud Voltage Stabilizer Question MG 14
Bruce Bowker voltage stabilizer British Motor Corp 6
Cain Fuel Gauge/Voltage Stabilizer Triumph 1
M voltage stabilizer Triumph 3
Sarastro TR4/4A Exasperating experience with voltage regulators Triumph 3
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
Sopwith_Camel MGB voltage regulator MG 11
7 What voltage regulator? Other Cars 21
R TR6 No voltage at solenoid tap Triumph 7
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
Kurtis TR4/4A Voltage Control Module Triumph 15
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
S TR2/3/3A grounding the voltage regulator Triumph 14
S TR2/3/3A voltage regulators gap and oxidation Triumph 10
Jim_Gruber Voltage Regulator Question Spridgets 4
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
NutmegCT Voltage gauge Restoration & Tools 1
Bill_S TR4/4A Failing Voltage Stabilizers Triumph 1
S TR4/4A voltage regulator - digital Triumph 13
TulsaFred Moss Lucas Control Box/voltage regulator Spridgets 4
N TR4/4A voltage regulator Triumph 5
C Voltage regulator Austin Healey 12
steveg Heater Blower voltage drop Austin Healey 8
M TR2/3/3A Voltage regulators Triumph 5
cmacmillan TR6 Losing voltage at + side of coil Triumph 12
F TR2/3/3A Voltage Regulator and Charging issues Triumph 11
R RB 106/2 12V Voltage Regulator Needed Austin Healey 1
Zimmycobra TR4/4A Question on Voltage Stablizer Triumph 6
R TR6 How does one test the voltage regulator in th late TR6? Triumph 2
Darrell_Walker High battery resting voltage - sign of imminent demise? Triumph 15
