Tube shocks on all four corners!
Morris
After one too many squirrlely corners on the drive home Friday, I decided it was finally time to do something about the rear shocks. I spent some time under the car with a measuring tape, and some time pouring through the Monroe catalog until I found the perfect candidate... a front shock for a 1981 Chevy K5 Blazer... a pair was on the shelf of my local big box, and they set me back $17 a piece.
The top of the shocks mount to the re-bound strap hole. I made a spacers from a some 3/4" thick aluminum bar stock using a hole saw (I had both lying around). I also had to use a longer bolt, but I had some of those lying around, too. I used pieces of fuel hose as shims in the upper shock mounts—a perfect fit! The shocks come with mounting hardware for the lower mounts. I removed the lower spring plates, drilled the hole that the stock shock link mounts to out to 5/8" and flipped the left and right sides (so that the mounting hole is lower). The whole job took about 3 hours.
Squirrlely rear end- fixed
Annoying vibration at 3500 rpm in 4th- fixed
Clanking noise when going over bumps- fixed
Of course, my kidneys are gonna have to get used to the ride. The back end is now TIGHT. I like it that way, but I do really feel the bumps in my guts.
Gundy
So I take it you put tubes up front earlier?
Good on ya pal! Ingenious solution. I love it!
I love how my lil Sprite handles with the tubes at the corners.
A little rough, but a price I'm willing to pay for the performance gain. Real seat of the pants type handling.
I took a corner the other day with Russ (toysruss) and he figured we had to pull a "G". ( I doubt it as the tires weren't screaming )
:driving:
Do you have a front sway bar? It really helps too.
JPSmit
cool! but now get us some pictures please :bow:
aeronca65t
Morris
Morris
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Just curios..why didn't you use the same model shocks that are in the front on the back?[/QUOTE]
The front shocks are much too long compressed and extended to work for the rears the way I have them set up.
Nial, didn't you have a write up on how you did your rears at one time? I looked for it this weekend but could not find it.
lesingepsycho
Wow, that's pretty cool! So simple. When you do that on the front, do you drain the shock oil from the lever shock so as not to interfere with the tube shock or do you leave it functioning and let the tube be sort of secondary? Kinda like a dual shock setup.
JACK
Morris
Morris
The shock is full of oil (to prevent seizing) but the valve is removed so that there is no resistance from the shock.
Morris An argument against tube shocks... Spridgets 2
B Tube Shocks Conversion Austin Healey 19
KVH Replacing Rear Lever Shocks with Tube Shocks Triumph 24
W tube shocks part # MG 15
AUSMHLY After market rear tube shocks Austin Healey 28
davester MGB MGB rear tube shocks...which ones? MG 18
mgbmedic MGB rear tube shocks for MGB MG 20
C Shocks: Rebuild Lever Arms or Tube Conversion??? Triumph 23
R TR6 TR6 rear ride height with tube shocks Triumph 5
T tr4-rear tube shocks Racing 2
bobmga62 MGA Tube Shocks form MGB to MGA MG 4
R Tube Shocks Triumph 14
C Tube Shocks on Midget? MG 1
aeronca65t Spridget Tube Shocks Austin Healey 8
tinman58 TR2/3/3A Vent tube Triumph 3
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
D Capillary Oil Tube Fastener Austin Healey 5
P MGB Tube axle wear MG 3
M Capillary Tube repair Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
G Stator Tube Nut and Olive Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
71TR6 TR2/3/3A TR3A Breather Tube Attachment Triumph 6
C TR2/3/3A stator tube Triumph 6
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Jim_Gruber Pages from Porter Spridget Restoration Manual on Seat Recovering, You Tube Videos Spridgets 4
D TR2/3/3A stator tube will not go down Triumph 0
AUSMHLY Tube vs Tubeless discussion :] Austin Healey 28
F TR2/3/3A Tie member[front apron support tube] Triumph 11
S Wanted stator tube Austin Healey Classifieds 0
S stator tube nut Austin Healey 7
D Best little tube bender Restoration & Tools 8
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
K For Sale Curved tube intake manifold...2" Triumph Classifieds 2
M Questions about stator tube and trafficator fixation Austin Healey 31
X BE jacking tube access holes and top bows. Spridgets 1
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
D BT7 stator tube Austin Healey 39
J TR6 TR6 Cross Tube Differences? Triumph 6
R Capillary tube temp gauge Austin Healey 7
