Wedge TR8 Starting Issue
RSMTR8
Here is the latest issue. Every once in a while when I put the key in the ignition, and turn it to start, NOTHING happens, the lights on the dash light up, but thats it. Then, I will turn the key back to the off position, then turn it to start again, and BAM, it fires right up! Any ideas? Starter, loose wire, relay?
Thanks!
Rod
kodanja
you may want to check the wire connection on the starter 1st...
that happen to me so I changed out the ignition switch , it still did it. when I pulled the wires off the starter they were very greasy, I cleaned them up put them back on and it fired right up... /ubbthreads/images/graemlins/england.gif
Airfix
Member
What was the outcome of the fuel tank problem?, did you repair or replace it, how much did they end up charging you?
DougF
I had a similar problem with the plug running into the ignition switch. A wire did not want to make good contact inside the plug, thus not making a connection with the harness.
Following you wiring diagram, make sure all of your connections are clean and firmly attached.
RSMTR8
RSMTR8
Well, funny you should ask, I just picked up the car this afternoon, to the tune of $950 total parts and labor. Here is what "Goldi" got for my $950. A fully refurbished gas tank both inside and out, and new rear engine/transmission mount, new 80A Lucas Alternator, new coil, and New Rear Bushings (4). That total was for all of the above including all the labor to take everything out, and put everything back in! The labor was killer alone about $600. Now I have 3 new issues, I need a new starter, and a new Master and Slave Cylinder. As I was driving my "Money Pitt" home, the clutch was feeling VERY soft at times, and normal at others. So I was not even half way home, so I turned around, the mechanic did a few checks, then called Woody to confer, and they both agreed that since they were both original that I should replace them both. As far as the starting issue, that has been slowly getting worse over the last couple of weeks, and gets worse once the car is warm. Again he ran a few test and spoke to Woody and by the "clicking" noise and where that noise was coming from they both agreed the starter was on its way out. So all 3 parts are on they way from Woody. So I am about to drop another $500 on parts and labor included next week! I figure at this point the only major thing that has not been replaced on this car is the Radiator! So I am just waiting for that to leak! Wish me luck, I think I need to go to the Casino and win some money to pay for all this!!!! Just kidding, driving this car is gambling enough for me!
Thanks!
Rod
p.s. I finally have a nick name for my 8 "GoldiCostsA-Lot"
:cool:
Airfix
Member
$900 doesn't sound too bad if it included all the parts, I'd agree, sounds like the starter, as they age they are less tolerant of the heat under the hood.
Keep us in the loop, look on the bright side, you give us somebody to compare to when we have to spend money, "at least I'm not spending as much as that RSMTR8 guy"
Good luck, it's worth it.
P Wedge Starting problems TR8 Triumph 3
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
tr6nitjulius Wedge Rare TR8 Triumph 0
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
Hamish Racing TR8 IMSA GTO around Spa Racing 0
MadMarx Wedge Dijon 2019 - Triumph TR8 IMSA GTO Triumph 0
MadMarx General TR Spa Summer Classic 2019 - TR8 IMSA GTO Triumph 1
MadMarx Brands Hatch - Triumph TR8 IMSA GTO Racing 0
MadMarx General TR Brands Hatch - Triumph TR8 IMSA GTO Triumph 0
MadMarx Wedge The IMSA TR8 is ready to go again Triumph 7
MadMarx Wedge IMSA TR8 video with some roar Triumph 0
MadMarx Triumph TR8 at Spa Racing 0
MadMarx Le Mans - YTCC - Triumph TR8 IMSA Racing 1
B Gold TR8 Waxhaw N.C. Spotted 2
MadMarx Wedge Canadian Group 44 TR8 at Hockenheim Triumph 2
MadMarx Wedge TR8 IMSA at Le Castellet Triumph 1
J Wedge TR8 research before purchase Triumph 16
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
S Wanted TR8 with blown motor or no motor Triumph Classifieds 0
T Wedge Triumph TR8 for Sale - 1,020 miles Triumph 3
S Wedge tr8 front end Triumph 0
S Wedge TR8 starter solenoid details? Triumph 3
S Wedge Tr8 manual Triumph 2
S Wedge Need help with TR8 no spark Triumph 7
MadMarx Wedge IMSA TR8 goes on Salzburgring Triumph 6
S Wedge TR8 Starter wiring help needed Triumph 18
Rut Wedge TR8 for sale Triumph 1
MadMarx Spa Summer Classic - IMSA TR8 Racing 0
MadMarx Wedge Spa Summer Classic - IMSA TR8 Triumph 7
B Wedge tr8 oil pressure switch number needed Triumph 3
G Wedge TR8 Classified? Triumph 0
G Wedge New to me TR8 Barn find Triumph 8
MadMarx Wedge IMSA TR8 - a recent photo Triumph 3
MadMarx Wedge IMSA TR8 - Spax on the rear axle Triumph 3
W TR8 brake aclipers on a Spridget Spridgets 38
MadMarx IMSA TR8 on the NĂĽrburgring Racing 3
MadMarx Wedge IMSA TR8 is racing Triumph 7
tr7andtvr Wedge TR8 Rotor Specs? Triumph 0
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
tr7andtvr Wedge TR8 calipers? Triumph 3
tr7andtvr Wedge Tr7, Tr8 or SD1 3.08 rear needed.... Triumph 25
Mickey Richaud General TR TR8 Folks Triumph 0
T Wedge TR8 parts car Triumph 3
philman Wedge Tr8 on local craigs list Triumph 11
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
Darrell_Walker Wedge Rimmer's front rally spoiler installed on my TR8 Triumph 22
JFS Wedge TR8 Hazard Flasher Triumph 15
aeronca65t TR7 / TR8 on Garden State Parkway - NJ Spotted 0
