crj7driver
Going to work on the Tr a bit and wanted to know what grease you recommend for the polyurethane suspension bushings. Installed new bushings about 5 yrs ago and they are creaking badly now.
Also any ideas on what to look at/fix regarding a jumpy speedometer needle? already pulled and greased/oiled the cable, it is good, with gentle bends.
The speedo needle will jump from 0 to around 30 when just starting to roll and settles down the faster the car goes. While doing 60-70 mph it will oscilate 5mph while holding the throttle steady.
Thought I would try somthing before spending $200 on getting it rebuilt.
thanks
thanks
