TR6 tr6 horn
sd80mac7204
depends on the year of the car
martx-5
According to these wiring schematics, the '69 TR6 doesn't have a relay, and the horns ground through the horn button. '70 and up show the horns grounding from the horn itself. I don't know if it grounds through the casing, or if there is a second terminal, then it would need a separate ground wire.
Geo Hahn
martx-5 said:
According to these wiring schematics, the '69 TR6 doesn't have a relay, and the horns ground through the horn button...
Dang, you're right. A relay was added to that circuit with the TR4A then dropped. apparently with the TR250. Not sure why they did that as adding a relay to that circuit greatly improved reliablity of the horns on my TR4.
Sixpack TR6 Horn Mystery Triumph 3
P TR6 TR6 Horn Relay Problems Triumph 8
T TR6 TR6 Horn Triumph 20
W TR6 tr6 horn aftermarket Triumph 1
W TR6 tr6 horn button Triumph 2
W TR6 TR6 Horn only works when key is off Triumph 27
T TR5/TR250 TR6 Horn Relay Triumph 1
W TR6 tr6 horn wiring Triumph 1
C TR6 TR6 horn repair Triumph 1
W TR6 horn blows tr6 Triumph 4
I TR6 TR6 horn help please Triumph 13
I TR6 TR6 horn help please Triumph 2
mabbott TR6 TR6 horn relay? Triumph 1
C TR6 69-TR6 horn problem Triumph 4
wangdango TR6 '76 tr6 horn push Triumph 1
B TR6 TR6 horn button intsall Triumph 11
C TR6 TR6 Dash replacement, now only the horn works Triumph 6
I TR6 TR6 phantom horn Triumph 2
T TR6 TR6 horn button Triumph 34
2wrench TR6 Help with horn removal '74 TR6 Triumph 6
mrv8q TR6 TR6 horn button rebuild Triumph 4
S TR6 1975 TR6 no horn Triumph 5
Brosky TR6 Horn problem with TR6 Triumph 12
B TR6 Horn Assembly Question 74 TR6 Triumph 2
BierRunner TR6 TR6 Trunk Lock Striker Triumph 1
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
