TR4nut
Whoever complains about minor Triumph electrical troubles has never tried to fix a bad horn ground on a TR4. My horns were never strong, and after storing the car for a year they don't make a peep.
I've traced the trouble to the ground in the steering column - the trouble is the bad ground seems to be in the steering couplings themselves. I do have all ground wires installed, but even with those you still have to rely on a good ground through the column and I believe sufficient corrosion has built up in the joints so that I have a lot of resistance and not enough current to run the horns.
Aside from my whining and pleas for pity from the Triumph crowd, I was thinking of converting to a TR4a-6 style relay system. Main current driving the horns would not go through the column, the column ground would only open/close the relay. My hope is with less current draw for the relay the resistance I see in the steering won't be as much an issue.
Does this make electrical sense? I don't have a TR relay, but I do have an aftermarket relay marked L-B-S. I'm also trying to figure out if I can use this 3 prong relay but right now I'm drawing a blank. Ideas/sympathy welcome.
Randy
Randy
