Twin H6 carbs. I was advised that my "jet lever to cam" link was set in the wrong hole of my fast idle cam, so I moved the link arm to the next hole on the cam.
Started up and the engine raced immediately to 5000rpm. Kicking the gas pedal changed nothing. I cut the switch within 5 seconds. Linkage isn't stuck anywhere on the carbs or throttle as far as I can tell.
Figured this is not the best way to treat a cold engine, so I moved the link arm back to the original hole (the middle one) in the cam.
Engine still races at 5000rpm. Then tried the hole at the opposite end of the cam. Same thing.
I haven't run it enough to warm it up, as I fear doing some damage. The fast idle screw isn't touching the cam. If it were, I'd think the idle would be even faster. I haven't turned either of the throttle adjustment screws.
Anyone have a suggestion on what I did wrong?
Thanks.
Tom
Thanks.
Tom
