I'm right there with you -- if only in spirit. Today I'm going to be dropping the lower A-arms and removing the springs. My steering was VERY tight, and after removing the center link I found out why. The idler arm was virtually frozen solid. The mechanical advantage of the steering wheel/box was enough to move it, but you could not even budge it by hand -- that will be replaced. In addition, I am replacing the upper ball joints, trunions, tie-rods, shocks, ALL bushings, both bump-stops, new rotors and bearings and rebuilding the steering box. If I find anything "unusual", I will let you know.
