TR3/4 Cylinder head temperatures?
karls59tr
Bronze
Anyone know what a "normal' cylinder head temperature would be for a stock TR3 with a mild street cam and header and what the temperature would be if it was in the "danger" zone?
MadMarx
normal would be 185F.
sightly above wouldn't hurt but isn't normal.
Chris
K TR2/3/3A Can porting a TR3 Cylinder head be a DIY job? Triumph 6
G TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection Triumph 2
K TR2/3/3A The Aluminum Plug in the Cylinder Head ?[Again]TR3 Triumph 2
Marvin Gruber TR2/3/3A TR3/4 cylinder head differences Triumph 3
TR4nut TR4/4A Aluminum plug in TR3-4A cylinder head? Triumph 4
E TR2/3/3A TR3 Cylinder Head Lubrication Triumph 11
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
A TR2/3/3A TR3 door handle lock cylinder Triumph 4
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
mgedit TR2/3/3A Master Cylinder 56 TR3 [Lockheed] Triumph 14
mgedit TR2/3/3A Lockheed Master Cylinder 56 TR3 Triumph 2
M TR2/3/3A TR3 slave cylinder, What I'm I doing wrong Triumph 2
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
T TR2/3/3A Is there a Silicon safe Master Cylinder for TR3? Triumph 21
B TR2/3/3A TR3 Cylinder Sleeve Installation Triumph 10
mgedit TR2/3/3A 56 TR3 Master Cylinder Issues Triumph 17
mgedit TR2/3/3A Master Cylinder 56 TR3 Triumph 3
PeterK TR2/3/3A Classic Gold TR3 Master Cylinder Triumph 2
PatGalvin TR2/3/3A TR3 Cylinder Liner Install Question Triumph 6
T TR2/3/3A TR3 clutch slave cylinder Triumph 14
mrv8q TR2/3/3A TR3 Clutch Master Cylinder Triumph 20
mountainman TR2/3/3A TR3 slave cylinder adjustment Triumph 4
Tinkerman TR2/3/3A TR3 Master Cylinder Box Mounting Triumph 9
H TR2/3/3A TR3 Master Cylinder Removal Triumph 5
Q TR2/3/3A TR3 Brake Master cylinder rebuild Triumph 5
mountainman TR2/3/3A TR3 Rear Whelel Cylinder Install Triumph 10
P TR2/3/3A TR3 Slave Cylinder Return Spring Triumph 3
RedTR3 TR2/3/3A TR3 Clutch Slave Cylinder Adjustment Triumph 3
martx-5 TR2/3/3A Follow-up on TR3 Master Cylinder Resevoir Triumph 2
RedTR3 TR2/3/3A TR3 Cylinder Heads Triumph 10
J TR2/3/3A TR3 Master Brake Cylinder Stripped Fitting Triumph 1
martx-5 TR2/3/3A TR3 Ignition Lock Cylinder Triumph 3
txtr3 TR2/3/3A TR3 master cylinder replacement hints Triumph 3
S TR2/3/3A tr3 slave cylinder quality Triumph 8
